HELP! Heater Core Replacement, Now Jeep Won't Start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > HELP! Heater Core Replacement, Now Jeep Won't Start
Unread 11-22-2012, 02:23 PM   #1
cdcutsha
Hello Everyone
Today, I replaced the heater core in my 1988 4.2 YJ. It actually went pretty well, only took a couple of hours. Got everything back together and now the jeep won't start!
It cranks (turns over) but it won't (fire) start. Worked fine yesterday, but now today after heater core change it's dead in the water.
Has anybody ran into this before... could use some advice.
cdcutsha is offline   Reply With Quote Quick reply to this message
Unread 11-22-2012, 02:32 PM   #2
stenyeart
Forget to hook something back up?
Are you getting fuel and spark?
stenyeart is offline   Reply With Quote Quick reply to this message
Unread 11-22-2012, 04:00 PM   #3
Luuca
Typical /f12 Hooligan
Luuca's Avatar
There is a ground wire that attaches up above the battery tray. It attaches to one of the bolts that you needed to remove to release the heater box. My guess is you probably either have a bad ground at that point because you forgot to hook it back up, or you painted that area and need to expose metal so the ground is better connected.
91 YJ "Alice" 2.5L, AX5, 2.5" OME 36Rs, Revolvers, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R Busted Knuckles YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline   Reply With Quote Quick reply to this message
Unread 11-22-2012, 04:23 PM   #4
cdcutsha
Getting fuel, i'm getting ready to tear back into it, to see what is going on. Ill check the grounds, and spark issues... idk.. it's just really weird.
Unread 11-22-2012, 04:41 PM   #5
Louie4
Start tracing back your voltage from the distributor to the coil. If you're not getting spark to the distributor see if the coil has 12 volts. Have you checked your fuses?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 11-22-2012, 04:49 PM   #6
cdcutsha
Double checked that ground wire that lucca spoke about, it wasn't ever removed.. thanks louie4 I will try that next.. the only other thing that I noticed, that there is a (relay)? near the battery box, where the power wire off the starter goes into,, it had gotten wet from the anti-freeze when I removed the heater core hoses from the firewall. that could be something but idk.. it's just really wierd, because I didn't really mess with anything electrical in this process.
Unread 11-22-2012, 07:49 PM   #7
Old4X
1990 CJ7
Check the wires to the start relay. It is the square box just below where you were working. There are several recent threads on how the wires are arranged if it isn't obvious when you inspect it.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote Quick reply to this message
Unread 11-22-2012, 08:59 PM   #8
TSEJEEPERS
TSEJEEPERS's Avatar
Pull your distributer cap off, dry it off and spray it down with WD40.
You could have got mosture in it when you pulled the hoses.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Unread 11-23-2012, 09:14 AM   #9
cdcutsha
Checking everything today ( keeping fingers crossed ) hopefully it's something simple.
Unread 11-23-2012, 01:46 PM   #10
cdcutsha
OK, checked everything! can't find the problem, I replaced the starter relay, coil and battery. The distributer looks good. idk still won't start just not getting a spark. Bought ready to pack it up and trailer down to my mechanic
Unread 11-23-2012, 09:47 PM   #11
Old4X
1990 CJ7
Can you fill out your profile so we know what equipment is installed on the jeep? Nutter, carb, stock ICM, etc.?
Unread 11-29-2012, 09:01 AM   #12
cdcutsha
Got the jeep back up and running. It was the simplest thing, as they usually are.. The ECM somehow came loose when I pulled the heater box out, took the mechanic 30mins to figure it out. and back on the road I go. Thanks everyone for the help.
heater core , ignition , start
