Help a girl out my Jeep wont start !!! - JeepForum.com
post #1 of 53 Old 08-16-2011, 12:29 PM Thread Starter
Jeeplady13
My 95 yj was having a few hiccups while driving on the highway it seamed as if it was missing, it was fine idling but hit high speeds and it missed. this morning it crapped out on me on the highway, so i got it towed back to my shop. i pulled the distributor cap off and the rotor. the cap and rotor looked in really rough shape so i got NAPA to get me new plugs, wires, cap and rotor put it all back together and she still wont fire! any suggestions?
Jeeplady13 is offline
post #2 of 53 Old 08-16-2011, 12:33 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Start cheap and simple.
Fuel Filter.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #3 of 53 Old 08-16-2011, 12:40 PM
TheNewbie
You did what I would have done first. But if the new cap and rotor didn't help I'd be looking at a clogged cat or fuel filter.
Are you getting good fuel pressure?
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #4 of 53 Old 08-16-2011, 12:47 PM
R3V413
Are you getting spark from your coil? And if so, what color is the Spark?
R3V413 is offline
post #5 of 53 Old 08-16-2011, 01:06 PM
Andywear
We're going to need pic's before this problem gets fixed.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #6 of 53 Old 08-16-2011, 01:07 PM
zeus87gn
1987 YJ Wrangler
Did you double or tripple check your firing order?
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #7 of 53 Old 08-16-2011, 01:07 PM
Que89YJ
Couple things Jeep girl. First things fist though: Love the Jeep collection!
Check for fuel and spark. Spark by pulling a wire and hold it near ground to see if it arc. Fuel by depressing the schrader valve on the fuel injector rail. Fuel should come shooting out of it. Check the codes. I just posted how on this thread at the bottom:
http://www.jeepforum.com/forum/f12/e...ently-1253607/
Que89YJ is offline
post #8 of 53 Old 08-16-2011, 01:32 PM
pasinbuy
Check your CPS. It is the sensor on the bell housing, driver side. Unplug it, wait a minute, plug it back in. If your Yj then starts go get a new CPS.
pasinbuy is offline
post #9 of 53 Old 08-16-2011, 01:37 PM
Boodyrider
I'm leaning towards a fuel pum as you mentioned issues above idle. Fuel filter first, but be prepared for a pump. To diagnose you really need to check fuel pressure at the schraeder, not just see if it squirts...
Also check fuel pump connector at the tank area, fuse, and relay for fuel pump.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #10 of 53 Old 08-16-2011, 02:40 PM Thread Starter
Jeeplady13
Firing order is good and spark is excellent, I just checked the fuel on the intake and nothing is coming out so I am thinking it's a fuel pump. If I turn the key I should hear the fuel pump working?? Thanks everyone for the help.
post #11 of 53 Old 08-16-2011, 02:43 PM Thread Starter
Jeeplady13
I have a fuel pressure gauge and I will hook it up right away because all I did was see if it squrted.
post #12 of 53 Old 08-16-2011, 04:11 PM
oldtime_ironman
Sounds about like the fuel pump - mine did the exact same thing when it went. FWIW those pumps need to have gas in the tank in order to keep cool. Mine fried because I tried to drive 30 miles home on 1/8 tank. Best bet if you get a new pump, is to always keep 1/2 tank of a good name brand gas in it.
oldtime_ironman is offline
post #13 of 53 Old 08-16-2011, 04:39 PM
bigbossd1030
Tps
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #14 of 53 Old 08-16-2011, 05:45 PM
Xpress
DOUBLE CHECK the firing order!!
The cap I bought from NAPA had cylinder 1 off by 1 notch. My Jeep wouldn't fire at all. After lots of headscratching, I decided to start futzing with the firing order. Moved the plugs over 1 notch and she fired to life.
All about that unibody life.
Xpress is offline
post #15 of 53 Old 08-16-2011, 05:58 PM
Hawk37
I had a similar problem with my 93. It actually turned out being the capacitors in the Pcm. I'd say check to see if your fuel pump.is getting power before you pull the tank and replace it. It'd be easy to test up at the relay in the fuse box. The caps are easy to replace if you know how to solder. There is a good write up about it on here too. Search pcm capaciters, or pcm fix.
Hawk37 is offline
jeep wont stay running, now wont start 89General YJ Wrangler Technical Forum 5 02-11-2011 05:57 AM
jeep wont start joeyrossmiller YJ Wrangler Technical Forum 2 08-17-2009 09:45 PM
Jeep wont start advice on where to start? vangosu TJ Wrangler Technical Forum 6 08-25-2008 08:28 AM
CEL Jeep wont start...PLEASE HELP! itsgroll YJ Wrangler Technical Forum 23 05-29-2008 07:45 PM
Help!!!Jeep wont start. bob082484 YJ Wrangler Technical Forum 13 03-08-2007 03:46 PM
