HELP getting my C clips off axle - JeepForum.com
post #1 of 4 Old 02-07-2007, 08:14 PM Thread Starter
conor.davis
conor.davis's Avatar
I have a D35 on my TJ but im posting it in here to get advice from you YJ guys.
I have an Aussie locker in there that is posing the problem because i cant see how the c clips can come off with that locker in the way.
Has anyone else had this problem?
I am pushing in the axle to expose the c clip, but i cant see it.
thanks
2001 Wrangler Sport 4.0, 5-speed, 4.11's, detroit trutrack (front), aussie locker (rear), 4.5'' Rubicon Express, K and N cold air intake, Flowmaster 40 series muffler, 33" BF Goodwrench Mud Terrain, Warn 8,000lb Winch, 6" extended fender flares, Bestop oversize tire carrier, Explorer Pro Comp off road lights.
conor.davis is offline
post #2 of 4 Old 02-07-2007, 08:22 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Sometimes you have to use a small poker (for lack of a better term) and rotate the c-clip some so the open area of the c-clip is visible. Then use a tool to rotate it around again so the open end of the c-clip is at the rear of the opening in the diff.
Did you remove the cross-pin first? If not, you won't be able to get the c-clips out.
This is a pic of me removing an 8.8 c-clip fmom my ARB'd F8.8 when I use to have c-clip (don't have them anymore), but this should give you an idea.
Joe Dillard is offline
post #3 of 4 Old 02-07-2007, 08:34 PM Thread Starter
conor.davis
yeah that kind of helps... but there is spacers in there that make it almost seem impossible.. i think its an aussie locker thing. im about to throw that d35 piece of junk in the trash and order a D44 for a couple grand...
post #4 of 4 Old 02-07-2007, 10:23 PM
93YJfalcon
If I remember this right... The side gears in a Aussie have a little channel in them for the C-clip to fit out through. It's in the area where the teeth mesh between the side gear and whatever the middle parts are called. If You don't have the carrier facing the right way it will look too narrow to get the clip out through.
EDIT: Check out htis pic
http://www.4x4xplor.com/images/aussi...cker-parts.jpg
The channels are between the cam gears and the axle gears. Just on one side though. You cant see them in the pic, but it goes between the teeth.
ROCK OVER LONDON... ROCK ON CHICAGO!
93YJfalcon is offline
front axle u joint replacement, remove c clips? rutacon05 TJ Wrangler Technical Forum 2 07-15-2008 01:56 AM
Help with Posi-lok E clips YJames90 YJ Wrangler Technical Forum 10 05-05-2008 06:49 PM
C-clips GreatWhiteYJ YJ Wrangler Technical Forum 3 01-25-2008 01:28 PM
cant get c-clips off rebuiltyj TJ Wrangler Technical Forum 2 11-30-2007 03:09 PM
C-clips???? Jash927 TJ Wrangler Technical Forum 3 03-16-2004 10:22 AM
