Help with Gear Swap - JeepForum.com
post #1 of 6 Old 07-09-2001, 03:15 PM Thread Starter
Drewson
Help with Gear Swap
I have a 93 YJ with the 2.5L, soon to have the 4.0L if I can find the computer and all the harnesses.
My questions is this: I want to remove my 4.10/4.11 gears for 4.88's. But the guy at the shop said that my stock 35 would be asking for trouble since the new splines would be smaller. He suggested installing a "Super 35", which he said adds a detroit locker and give the performance of a Dana 44.
Is this necessary? Is it worth an additional $1300 installed?
Drewson
1993 YJ 2.5L - 4.0L Swap Soon!
35" TSL on 15x10 Wheels
Chrome/diamond plate everything not welded on
Drewson is offline
post #2 of 6 Old 07-09-2001, 03:56 PM
winokko
Drewson....if you go with the axle/gear swap I'd be interested in your old stuff! Let me know what you decide.
95, 4.0, 4" sky jacker lift, warn 9500i, tomken rear w/ swing out, 33x12.5 pro comp mud's, 3" body lift, sway disconnects, NO track bars & custom front bumper
winokko is offline
post #3 of 6 Old 07-09-2001, 09:06 PM
grinder
well I would say that you are putting a lot of starain on the 35,IF you wheel a lot or just wheel HARD. A lot of guys have busted the dana 35 while running 35 in. tires. A common swap is a ford 8.8 (very strong)out of and explorer and you get disc brakes as a bonus. Or if you are lucky you might find a 8.25 out of a cherokee that had a tow package on it and they are almost as strong as the 44. The 8.25 chry. is a direct swap.Check your options first to see where you can save some cash.
the best $8,000 jeep that $12,000 could build
grinder is offline
post #4 of 6 Old 07-09-2001, 09:10 PM
grinder
I'm sorry the 8.25 might not be a direct swap!! I was thinking xj not yj My Mistake!
grinder is offline
post #5 of 6 Old 07-09-2001, 11:14 PM
hamyscj
The shop is giving you information for the optimal performance of your jeep. Obviously it is your choice. The ford 8.8 is an excelent choice. I just put one in my bro's 92 YJ. It is fairly straight forward and fits like a glove. Rock on, Hamy.
One Way Up Racing
Romans 10:9
hamyscj is offline
post #6 of 6 Old 07-10-2001, 10:57 PM
osburn
osburn's Avatar
Personally, I think the term "Super 35" is an oxymoron. You'd be better off spending a few bucks on some spare shafts for the 35 until you can afford a real swap.
Besides, with the 4.0 the 4.88s would be way too low. 4.56s are too low unless you're going to run 35" tires (not recommended with the Dana 35) or you're a rockcrawler and can stomach the high revs on the highway.
Matt Osburn
Score 1032
osburn is offline
1st gear swap? rtyler13 TJ Wrangler Technical Forum 4 12-29-2009 09:29 AM
Gear Swap or Axle Swap? Zazoos YJ Wrangler Technical Forum 3 06-02-2009 11:29 PM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
Gear Swap Sungard YJ Wrangler Technical Forum 6 03-20-2008 08:50 AM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
