Help with front axel shift motor vacuume line harness! - JeepForum.com
post #1 of 2 Old 04-05-2002, 08:34 PM Thread Starter
highonthai
My axel shift vacuume harness was all screwed up from the previous owner, I thought I would replace it today, one end to the trans the other to the front axel.
Where do the RED the BLUE and the Black hose connet to?(no brainer)
That leaves three connection to make.
Does the black hose go to the indicator switch?
Are both the red and blue just vacuume lines? I mean can they just hook into any vacuume soruce?
HELP!!
I remember seeing a post of diagram for the front shift vacume harness somewhere but , I cannot seem to locate it now.
Thank's in advance..
highonthai is offline
post #2 of 2 Old 04-05-2002, 09:19 PM
bigjeep39
bigjeep39's Avatar
go with the 4x4 posi lock a sure fire way to have a rock solid shift into 4wd without buying the 850 dollar swap to the warn lockouts.
Shawn
1998 TJ
Slow steady project.
bigjeep39 is offline
Axel Shift..?????? MUDDY94 YJ Wrangler Technical Forum 0 01-25-2009 04:15 PM
Questions about a front Dana 30 axle w/ vacuume disconnect FlyersPh9 YJ Wrangler Technical Forum 5 10-23-2008 12:51 AM
Front Axle Shift Motor Fred007 YJ Wrangler Technical Forum 6 10-17-2007 02:02 PM
Front Axel Seal for Solid axel swap Mighty Thor YJ Wrangler Technical Forum 4 03-04-2007 11:13 AM
Help with front axel shift motor! highonthai YJ Wrangler Technical Forum 3 04-03-2002 10:54 PM
