Help with front axel shift motor! - JeepForum.com
post #1 of 4 Old 04-02-2002, 08:13 PM Thread Starter
highonthai
I dont seem to be getting any indicator lights when I shift into 4X? Is this telling me that My shift motor is not working?
What is the most common problem with thefront axel shift motors? Can I bypass the S-motor ?
any help wood be great!!
Thanks
highonthai is offline
post #2 of 4 Old 04-03-2002, 06:54 AM
RodeoRob
RodeoRob's Avatar
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by highonthai:
<strong>Can I bypass the S-motor ?</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Yea, they make cable actuated replacements that are more reliable... you can find them at places like Quadratec. But they are somewhat pricey.
Or, you could replace the 2 piece shaft with much stronger 1 piece TJ shaft and defeat the need for the shifter motor all together. The front driveshaft would turn all the time then, but thats no big deal, if you have a front locker it would anyway. Worst case you might have to go get the front driveshaft balanced.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 4 Old 04-03-2002, 03:54 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
You might have a broken vacuum line somewhere. The shift motor is vacuum activated and if one is broken or pulled out the shift motor won't engage. I'd check those out first.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #4 of 4 Old 04-03-2002, 09:54 PM
Bob K
Bob K's Avatar
Four possibilities:
1. Bad vacuum motor.
2. Bad vacuum hose.
3. Bad vacuum switch (on t-case)
4. Indicator light doesn't work.
Take your time and track down the problem. I have several times.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
Axel Shift..?????? MUDDY94 YJ Wrangler Technical Forum 0 01-25-2009 03:15 PM
axel shifting motor- vacuum tubes?..wtf? supermopar YJ Wrangler Technical Forum 2 01-06-2009 01:39 AM
Front Axle Shift Motor Fred007 YJ Wrangler Technical Forum 6 10-17-2007 01:02 PM
Front Axel Seal for Solid axel swap Mighty Thor YJ Wrangler Technical Forum 4 03-04-2007 10:13 AM
Help with front axel shift motor vacuume line harness! highonthai YJ Wrangler Technical Forum 1 04-05-2002 08:19 PM
