help finding a input shaft - JeepForum.com
post #1 of 6 Old 05-13-2010, 04:53 PM Thread Starter
jayhhaynes
i went to go put my new pilot bearing in and found the input shaft is broken off inside it. i need some help finding a new input shaft for my tranny.its a puegot ba10 . if you wanna know how it happened read this...http://www.jeepforum.com/forum/f12/np231-1024519/
if anyone has an old one id be happy to buy it from you
jayhhaynes is offline
post #2 of 6 Old 05-13-2010, 04:57 PM
burnout189
a new ax-15 would have an input shaft
sorry for being a smart*** lol
BARNHART'S AUTO REPAIR
burnout189 is offline
post #3 of 6 Old 05-13-2010, 05:02 PM
kloppk
edit.....
see post below
Kurt
kloppk is offline
post #4 of 6 Old 05-16-2010, 04:59 AM
kloppk
FYI - You PM In Box is full.
No problem, you can just send me a check for it. PM me your name & address so I can get it shipped to you, hopefully tomorrow.
kloppk is offline
post #5 of 6 Old 05-16-2010, 03:15 PM
kloppk
Just pulled apart the transmission to harvest the input shaft. Got the tranny all apart, removed the input shaft and found that one of the teeth on the input shaft gear is broken off
I checked the parts manual and the gear on the input shaft is part of the shaft and isn't removeable
Sorry to say I it's the only BA/10 I have for parts to canibalize.
Hopefully someone else on the forum will be able to provide one for you.
kloppk is offline
post #6 of 6 Old 05-16-2010, 03:22 PM
monkeyhouse
just call advance adapters or novak, they have the shaft you need. You can also just look in the classifieds for your t/c, but the adapter is cheaper.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
Input shaft 94YJgirl YJ Wrangler Technical Forum 9 05-17-2009 09:06 PM
AX-15 input shaft play Gomofast TJ Wrangler Technical Forum 1 07-28-2008 09:26 AM
AX-15 input shaft?? bluemuddyjeep YJ Wrangler Technical Forum 7 02-18-2008 06:53 PM
90 ax5 with 13 spline input shaft? subzeroedj YJ Wrangler Technical Forum 2 06-27-2007 06:08 PM
input shaft ax-15 pepijn YJ Wrangler Technical Forum 2 04-25-2005 11:42 AM
