Help: external clutch slave cylinder swap - JeepForum.com
post #1 of 1 Old 02-26-2009, 08:47 AM Thread Starter
Blacksmith13
1987 YJ Wrangler
Hello,
i am swapping my Peugeot tranny of my 87 YJ for a Ford NP435 4-speed.
The engine is a 258cui engine.
Clutch, Bellhousing and Clutch release arm come from a CJ7 with 258, T150 Transmission and mechanical clutch linkage.
I dont want to use the mechanical link setup
I want to install an external hydraulic clutch slave cylinder in my YJ to get rid of the stock internal one.
Which external jeep slave cylinder work best for my setup?
I considered a jeep slave cylinder made for a CJ 80-86 2.5l engine.
Maybe somebody has done a similar swap and can tell me what he has used for the clutch.
Greetings from Germany
Michael
Blacksmith13 is offline
AX-15 Internal to External Slave Cylinder Clutch line write up bigredcherokee YJ Wrangler Technical Forum 40 11-15-2014 03:10 PM
Any one have a Write up on external slave cylinder? Jwessel YJ Wrangler Technical Forum 2 08-22-2009 03:17 AM
Clutch Slave Cylinder External Vici0usX TJ Wrangler Technical Forum 3 07-05-2009 04:32 AM
leaky external clutch slave cylinder repair fish4life TJ Wrangler Technical Forum 6 05-05-2008 07:49 PM
Changing to an external slave cylinder 1992 renagade YJ Wrangler Technical Forum 6 01-30-2008 04:28 PM
