Help with door compatibility - JeepForum.com
post #1 of 16 Old 09-27-2011, 01:16 PM Thread Starter
dalehili
Hi, I'm new to the forum and new to jeepin, having just bought my yj about six months ago. I recently bought a supertop complete with frame and soft uppers to replace the worn patchwork top from the previous owner. Everything worked fine except the new door uppers. The pins don't line up with the holes in the doors, and the old uppers and frames are completely different. Do I have doors that are not yj doors, or what? I can't seem to find any existing write-ups about this. Thank you for any help you can offer.
dalehili is offline
post #2 of 16 Old 09-27-2011, 01:24 PM
texas_yj
on your old uppers, are the 3 pins all in a line, or is one offset about an inch? also, does it have a snap on the very front. the doors should also have a belt rail on it. CJs didn't have 1/2 doors, but TJ can be made to work by changing out the latches. also, is your new top a best top, or chinese? I've heard of some chinese ones not fitting right
and welcome
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt.
2) (Sold) 99 TJ, mustang 5.0 GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT, superlift 6" long arm, D30/44 w/ ARBs & yukons, customized warn bumpers, custom sliders, 12K winch w/ synthetic rope, custom paint
3) 2007 JKU being built now
texas_yj is offline
post #3 of 16 Old 09-27-2011, 01:27 PM Thread Starter
dalehili
The doors do have belt rails and a snap in the front corner. The old uppers front pin was offset a bit. What is the best solution, looking for someone with yj doors who wants to trade, or modifying what I have?
dalehili is offline
post #4 of 16 Old 09-27-2011, 01:29 PM Thread Starter
dalehili
Oh, and thanks for the welcome. It is a Bestop.
dalehili is offline
post #5 of 16 Old 09-27-2011, 01:32 PM
texas_yj
sounds like you have YJ lowers, the pins whould all be in a line
you may just need to 'tweek' the inserts or the pins a little to get it to work. hope the pick helps you compare.
edit, these are modified TJ uppers on YJ lowers in this pick, modded to work with a hard top
texas_yj is offline
post #6 of 16 Old 09-27-2011, 01:33 PM
Joey2123
I have a set of YJ frames if you don't figure it out. Well, complete uppers with little tears in the window.
Joey2123 is offline
post #7 of 16 Old 09-27-2011, 01:48 PM Thread Starter
dalehili
The new uppers have Velcro at the bottom and the top rear corner of the doors are rounded rather than squared.
dalehili is offline
post #8 of 16 Old 09-27-2011, 01:49 PM Thread Starter
dalehili
Thanks Joey. I'll definitely keep that in mind.
dalehili is offline
post #9 of 16 Old 09-27-2011, 01:57 PM
texas_yj
make sure Joey's are for the supertop, not the factory ones as they are different, as you have found out I'm betting the new ones got tweeked in shipping.
texas_yj is offline
post #10 of 16 Old 09-27-2011, 02:05 PM Thread Starter
dalehili
Ill post a side by side picture of the uppers when I get home.
dalehili is offline
post #11 of 16 Old 09-27-2011, 02:17 PM Thread Starter
dalehili
dalehili is offline
post #12 of 16 Old 09-27-2011, 02:30 PM
texas_yj
all I get is hungry (picture of brisket on upside down plate)
texas_yj is offline
post #13 of 16 Old 10-01-2011, 01:52 PM Thread Starter
dalehili
Here are pictures of mine.
Notice how the old one (on my door) has an offset pin. Also, I'm going to include measurements in my next followup post.
dalehili is offline
post #14 of 16 Old 10-01-2011, 02:00 PM Thread Starter
dalehili
On my old (the one that fits) uppers, it is 15 inches from the front pin to the middle, and 14" from the middle to rear pins.
On my new upper, it is 11 3/4" from front pin to middle, and 14 1/4" from middle to rear pin.
dalehili is offline
post #15 of 16 Old 10-01-2011, 03:22 PM
NonRubicon
Sounds like you have the soft uppers for the two-two piece soft doors that fit the Bestop Supertop. I believe the soft uppers for the hard half doors should have the belt rail. The uppers for the two piece soft doors have a velcro strip. It would seem that the two are not interchangeable.
NonRubicon is offline
CJ YJ Door Compatibility 92WhiteLightnin YJ Wrangler Technical Forum 3 08-10-2010 05:51 PM
Door Surround Compatibility? rs4race TJ Wrangler Technical Forum 6 03-04-2010 10:52 PM
Half door compatibility AndrewMuadDib TJ Wrangler Technical Forum 8 11-21-2008 12:04 PM
YJ/TJ Compatibility Wheelin90YJ YJ Wrangler Technical Forum 5 04-21-2008 09:07 PM
TJ and XJ Compatibility? mknherhappy TJ Wrangler Technical Forum 2 10-18-2007 03:51 PM
