Help? Do you have a Ford 8.8 and 4" lift? - Page 2 - JeepForum.com
post #16 of 42 Old 04-21-2010, 09:30 AM
K4KAS
Yes yours. Its good, I guess!
Angle finder or degree finder. Its in the tolls section in Lowes. Usually around the carpentry.
K4KAS is offline
post #17 of 42 Old 04-21-2010, 09:32 AM Thread Starter
Jeeper_YJ
Originally Posted by DaveinHouston View Post
The dimension on mine is 14 3/4" to the bottom of the flange. Photo attached. You can't really tell in the photo but he axle pinion and driveshaft are parallel (at the same angle).
From TC bottom yoke to the ground is 20.5" and from axle flange to the ground is 14.25"
Jeeper_YJ is offline
post #18 of 42 Old 04-21-2010, 09:54 AM
DaveinHouston
Originally Posted by Jeeper_YJ View Post
I got 14.25-14.5". Maybe that's the 1* lower? Sounds close?
Also, from tc yoke to the ground I got 20.5"
It's close but again I'd be more concerned about the angles than the distance. Yours looks good in the photo but it's hard to tell. If you don't have any vibrations and visually the angles of the pinion and driveshaft look to be about the same I'd call it good. I spent a lot of time with mine sitting in the perches (not welded) pecking on it with a hammer and checking the angles before I tacked it. But I'm anal about that kind of stuff. I did the same thing to get the side to side distance right. I couldn't be happier with the 8.8 and the whole setup after it was complete. It was nice to get rid of that TC drop. My motor mounts were bad (I think the TC drop put too much strain on the stock mounts) so I replaced them (with Brown Dog) at the same time. It was like a different Jeep when I got it all done. Of course going from 3.55 to 4.10 gears helped too.
- 2003 Rubicon - 4" Lift, 35" KM2s, 5.13 gears, winch
- 1968 CJ5 - Dauntless V6, T-86, Dana 18, D27 & D44
- NRA Life Member - Licensed to Carry and Do.
DaveinHouston is offline
post #19 of 42 Old 04-21-2010, 10:03 AM
Unii
so you want the pinion the same angle as the driveshaft? maybe a degree or two lower?
Unii is offline
post #20 of 42 Old 04-21-2010, 10:03 AM Thread Starter
Jeeper_YJ
I have to agree! I do get a small vib though. Nothing like before. But, I do have a aussie locker in now and a wheel weight fell off. Not to mention the alignment is off. lol! From vib went from a bad 9 to a good 2-3 (1-good and 10-bad). So, it's better! I agree, nice to see the tc drop bracket gone.
I also like the disc brakes now too. Better stopping power. I am curious to see what the LSD in the 8.8 and aussie locker can now do. Both are new add-ons.
post #21 of 42 Old 04-21-2010, 10:03 AM
DaveinHouston
Originally Posted by uni View Post
does anyone have a write up on how to set pinion angle.
There are a bunch of write-ups out there but I didn't find any that went into a lot of detail on how to set the angle. Like I said earlier I set my axle (not welded to the perches) into the Jeep, laying on the perches and springs. I had jack stands under the springs with the Jeep's weight on the springs to simulate a normal stance. With the new driveshaft installed I tapped around on the axle until I got the angle and the side to side dimensions right. Then I tack welded the perches. I welded it out in place but you could remove it to weld out.
post #22 of 42 Old 04-21-2010, 10:07 AM Thread Starter
Jeeper_YJ
Without driveshaft in.
With driveshaft in.
post #23 of 42 Old 04-21-2010, 10:09 AM
DaveinHouston
I did mine with the driveshaft and pinion at exactly the same angle, but most write-ups suggest one degree lower to allow for a little axle wrap under acceleration. I figured there wouldn't be any axle wrap under most driving conditions. But who knows.
post #24 of 42 Old 04-21-2010, 10:21 AM Thread Starter
Jeeper_YJ
To check pinion angle. You put the angle finder on the TC and the axle? The reason I ask is I asked someone to measure the TC yoke to ground and their's sits higher. Wouldn't this change the pinion angle as well?
He got 20.5 from TC yoke to ground. I got 19.5"
He got 14 3/4" from axle flange to ground. I got 14.25"
So, by my math. His axle is .5" higher in the pinion angle. Not sure on an angle finder if that is a lot or not?
post #25 of 42 Old 04-21-2010, 10:55 AM
firefighter315
Joe Dillard offered up a quick trick on here once to find approx. 1 to 2 deg. below center line for the 8.8. If you run a string in line with the cast "rib" located on the side of the diff. housing that runs along the pinion portion by the flange and then put the other end of the string at the bottom of the TC output shaft (while keeping the axle end of the string in line with that rib), that line should be an approx. 2 deg. drop from center.
If using an angle gauge, you can still use a string to mimick the DS and just run it center U joint to center U joint, get the reading, then drop your pinion 2degrees below that. As cheap as they are, it just makes sense to get the angle finder and be sure before welding up your perches.
My YJ Build Thread
firefighter315 is offline
post #26 of 42 Old 04-21-2010, 10:58 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Gotcha. I'll have to check. What is the tool called so I can pick one up at Lowes?
Thanks
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #27 of 42 Old 04-21-2010, 11:05 AM Thread Starter
Jeeper_YJ
In my case where it's already done. How do you figure it out? Is there a math solution to figure it out based on the numbers I posted?
post #28 of 42 Old 04-21-2010, 11:06 AM
DaveinHouston
I checked the angle on the driveshaft (with it installed) and on the axle pinion. They should both be app. the same angle...pointing at the transfer case. I wanted to check it with the driveshaft installed to allow for the length of the double cardan joint. Either I got it right or got lucky because I have NO vibration. Visually it looks right too. I used two of the magnetic angle finders at the same time and pecked around on the axle until I was happy with it.
post #29 of 42 Old 04-21-2010, 11:09 AM
DaveinHouston
You could still attach an angle finder to the driveshaft shaft and to the flat spot on the axle and compare the readings. They should either be the same or 1 degree down on the pinion if that's what you want. Would take about ten minutes.
post #30 of 42 Old 04-21-2010, 11:09 AM
everydayXJ
The tool will be with the tape measures and levels, not sure of the exact name but you'll recognize it. Looks like a wheel with a flat base, hanging inside the degreed wheel is a pointer. The base(s) will be magnetic.
As for the $1k, that's what mine cost including the front end regear. I kept notes on what I bought and how much it cost.... big mistake!
8.8 $200
Install kit (MORE) $270
Wheel bearings $30
Wheel seals $15
gear oil $10
Brake lines $30
extended upper shock brackets $80 (very cool add on btw)
welding rod and a new helmet $40
D30 gears and install kit were $240
axle seals $30
u-joints $50
So, yeah it's a cool grand to do it right. If you were swapping into a 4cyl you would have avoided the front end expense I suppose.
eta:
Oh yeah, and another $10 for extra length racing studs for the 1" solid spacer I had fabbed up for the right side, gets width back to stock and help better center up that pinion.
Rock on!
eta2:
Hey Daveinhouston.... me too!
everydayXJ is offline
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
Help With Ford 9", or Ford 8.8 Cbaughn YJ Wrangler Technical Forum 10 10-29-2008 05:39 PM
Ford 10.25 vs Ford 9" Allen52105 YJ Wrangler Technical Forum 1 07-24-2007 06:45 PM
