Help? Do you have a Ford 8.8 and 4" lift? - JeepForum.com
post #1 of 42 Old 04-20-2010, 11:38 PM Thread Starter
Jeeper_YJ
If you have a ford 8.8 and a 4" lift I need your help. Easy request Can you measure from the ground to the bottom of the axle flange where the driveshaft goes? I need that measurement.
Thanks
Jeeper_YJ is offline
post #2 of 42 Old 04-21-2010, 12:03 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Tire size is going to play a part of this equasion.
Joe Dillard is offline
post #3 of 42 Old 04-21-2010, 01:35 AM Thread Starter
Jeeper_YJ
33x12.5x15
post #4 of 42 Old 04-21-2010, 03:36 AM
K4KAS
Im guessing you are wanting pinion flange measurement. As stated it will vary between vehicles. Even with the same size tire. I am also guessing that you are trying to find the correct driveline angle. Somebodys measurement may get you in the ballpark, but I wouldnt trust it. The correct way would be to use an angle finder which can be found cheaply at home depo or lowes.
K4KAS is offline
post #5 of 42 Old 04-21-2010, 06:53 AM
DaveinHouston
I've got that set-up but K4KAS is right. If you're trying to set the pinion angle put jack stands under the springs (so they are loaded with the weight of the Jeep) with the axle sitting in the perch on the springs. Adjust the angle of the pinion until the pinion and the driveshaft (obviously need the driveshaft installed) are straight and at the same angle. Some people say to have the pinion 1 degree lower than shaft to allow for axle wrap under acceleration but I didn't do that. Then tack weld the perches to the axle tubes. You can either weld it out under the Jeep or take the axle out to do it. I welded mine under the Jeep. I'll go take the measurement you've asked for a little later and send it to you.
- 2003 Rubicon - 4" Lift, 35" KM2s, 5.13 gears, winch
- 1968 CJ5 - Dauntless V6, T-86, Dana 18, D27 & D44
- NRA Life Member - Licensed to Carry and Do.
DaveinHouston is offline
post #6 of 42 Old 04-21-2010, 07:12 AM
DaveinHouston
The dimension on mine is 14 3/4" to the bottom of the flange. Photo attached. You can't really tell in the photo but he axle pinion and driveshaft are parallel (at the same angle).
post #7 of 42 Old 04-21-2010, 07:12 AM
Area.3.Fiftyone
^^^ What he said ^^^
Use an angle finder and point it 1 degree down from what you need.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #8 of 42 Old 04-21-2010, 08:05 AM
Unii
does anyone have a write up on how to set pinion angle.
Unii is offline
post #9 of 42 Old 04-21-2010, 08:13 AM Thread Starter
Jeeper_YJ
It's already done. Just wanting to see if it was done right.
post #10 of 42 Old 04-21-2010, 08:53 AM
everydayXJ
I see a $1k 8.8 swap there and you didn't buy a $10 angle finder? Cool!
For what it's worth I recall my pinion being at 18 degrees and the shaft at 19.
everydayXJ is offline
post #11 of 42 Old 04-21-2010, 09:05 AM Thread Starter
Jeeper_YJ
$1k? someone got screwed? I didn't pay close to that. Axle at JY was $177 (4:10 w/LSD) + misc parts to install and labor $150
17 3/4" is what I got on the DS with a 4" lift and 33x12.5x15. I was told 17 1/4" to 17 3/4" was a common measurement for a 4" YJ lift. You got 19"?
I will measure from ground to flange in a few and post.
Live and learn!
post #12 of 42 Old 04-21-2010, 09:16 AM
Unii
Live and learn!
19 degrees not inches....
Unii is offline
post #13 of 42 Old 04-21-2010, 09:20 AM
K4KAS
Man that's a clean Jeep belly!
K4KAS is offline
post #14 of 42 Old 04-21-2010, 09:27 AM Thread Starter
Jeeper_YJ
Mine? Good or bad?
post #15 of 42 Old 04-21-2010, 09:28 AM Thread Starter
Jeeper_YJ
Gotcha. I'll have to check. What is the tool called so I can pick one up at Lowes?
Thanks
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
Help With Ford 9", or Ford 8.8 Cbaughn YJ Wrangler Technical Forum 10 10-29-2008 05:39 PM
Ford 10.25 vs Ford 9" Allen52105 YJ Wrangler Technical Forum 1 07-24-2007 06:45 PM
