help, deep in the motor, the wallet, and still not in the mud - JeepForum.com
post #1 of 13 Old 05-26-2011, 02:34 PM Thread Starter
skysthelimit001
1987 YJ Wrangler
3 months ago i bought an 87 wrangler yj...i've been working on it ever since...after a few days i replaced some gaskets and the exhaust and noticed that the motor had a knock from the lower half....since then, i've bored out the block and installed every part brand new or reconditioned including: crankshaft, main and rod bearings, pistons, freeze plugs, camshaft and cam bearings, full gasket kit, harmonic balance, oil pump, etc....i fired her up late last night and there is still a knock about the same as it was before the rebuild slightly higher pitch....i'm so frustrated with it this jeep is fighting so hard i'm at a loss for what to do next...please any ideas would help
skysthelimit001 is offline
post #2 of 13 Old 05-26-2011, 02:44 PM
bec
new oil filter?did you run it with the drivebelt off?automatic transmission or manual transmission? could be a flywheel.just some suggestions if the motor was properly built
bec is offline
post #3 of 13 Old 05-26-2011, 02:51 PM
MONSooNmonkey
New oil pump, it is mechanical no?
Sadface :(
MONSooNmonkey is offline
post #4 of 13 Old 05-26-2011, 02:52 PM
MJMPC
Check your oil pan for dents. It dont takr much of a dent to hit the crank an sound like a rod going out.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 13 Old 05-26-2011, 03:02 PM
bec
i said oil filter if you did not change it and it was plugged up
bec is offline
post #6 of 13 Old 05-26-2011, 05:40 PM Thread Starter
skysthelimit001
1987 YJ Wrangler
brand new oil filter...its a manual tranny....no visible dents in the oil pan but i had someone helping me and he felt a knock vibration when he put his hand on the oil pan....the only thing i can think of is that something wasnt right w the crankshaft and main bearings, when i put it in the motor was on a stand and it was hard to turn it over by hand once i got it started it spun ok but not as easily as i would have liked....i should have used a feeler gauge but the napa auto parts called their machine shop and they swear the bearings match the cut on the crank...?????
post #7 of 13 Old 05-26-2011, 09:53 PM
bec
Sorry for the news,I would sure make napa responsible if indeed they gave you the wrong bearings.you don't think it is possibility a rod cap is turned backwards or cap is on wrong rod?first engine I built I completed block and turn crankshaft over and the crank got tight.pulled rod caps and found out that I had two caps in wrong location.switch em back and turned like a champ .that I what I got for not clearly marking the rod and caps.engine had been built before because there were several rods marked the same no.lesson well learned for me.
bec is offline
post #8 of 13 Old 05-26-2011, 11:26 PM
MJMPC
It doesnt take much of a dent to makt it knock. If the old motor knocked and this one does also almost have too be the same thing wrong with both.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #9 of 13 Old 05-27-2011, 12:25 AM
GOWAD
your not the only one my motor is doing the same thing ........ we took it a part 3 times still same knock
GOWAD is offline
post #10 of 13 Old 05-27-2011, 02:58 AM
bec
Now that my memory is coming back I do remember a bulletin.was the pistons you installed black coated?if not clearance issues need to be addressed.this was with a piston knock at idle.
bec is offline
post #11 of 13 Old 05-27-2011, 03:55 AM
bec
I'm sorry I believe that bulletin was on 93 or later.
bec is offline
post #12 of 13 Old 05-28-2011, 07:25 PM Thread Starter
skysthelimit001
1987 YJ Wrangler
i figured it out after another late night wrenchin it was a dent in the oil pan that looked so uniform and factory i thought it was supposed to b like that, i also forgot to put in a new crank pilot bearing....thanks for all the advice.....
i have a new set of issues now, im on my second set of new freeze plugs and their still leaking, i tried permatex gasket maker, next im gonna loosen the radiator cap and run the motor under lower pressure and c if the heat will help them seal....this yj is putting up quite a fight but i'll make her run smooth in the end weather she likes it or not!!
post #13 of 13 Old 05-29-2011, 12:44 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
If you do not use or make a 'tool' to tap in the freeze plugs so they are in straight they will leak no matter how much goop you put on them. Use a proper sized socket or section of pipe to tap them in straight. They should have a bit of Permatex on them but not gobs of the stuff.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
help needed , knocking , rebuild kit , stroker motor
My Check Wallet light came on :( MikeyJ TJ Wrangler Technical Forum 20 10-30-2010 06:54 PM
how should i empty my wallet next? lancer27 Wrangler General Discussion 10 12-22-2009 07:33 PM
Whats in your wallet? I mean toolbox wwhiker YJ Wrangler Technical Forum 13 11-09-2007 02:02 PM
Curiosity killed my wallet and the cat wheelinman03 TJ Wrangler Technical Forum 16 09-27-2006 10:13 AM
Water crossings: How deep is too deep? Dirty Backroads TJ Wrangler Technical Forum 32 11-27-2005 06:18 AM
