Help Deciding "how" to build my dana 44 and dana 60 - JeepForum.com
post #1 of 6 Old 08-11-2006, 11:34 AM Thread Starter
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
i have a 44 and 60 i'm about to build for my yj...i plan to continue to run the 39.5x18" boggers.... I have a 4 banger, ax5, and np231
both "new" axles are from a 1979 F250 (non-snowlow version)
one day i plan to swap in a 350, some sort of auto tranny, and a dana 300.... but not anytime within the next 3 or 4 years...... so.... the questions:
for the rear dana 60:
i have yukon 35 spline axle shafts... plan to bore axle shafts to fit them
plan on 5.38 gears (brand?)
planning on an arb locker but if i could buy a detroit and be guaranteed full lock when on the gas and know for sure that i wouldn't be wearing my tires more when driving on the street, i'd go that route and save a few hundred dollars.
what brand seals and bearings would be most recommended?
autozone, advanec auto, carquest, and napa are all near my home and easy to deal with.
disc brake conversion: who's kit is the most complete and most cost effective?
once converted to disc brakes i am told that i will need 16" wheels to clear the calipers... correct?
wheels... running the axles full width so i need a wheel with an offset that won't put me in both lanes of traffic.... h2 hummer wheels with the weld-on beadlock kits? maybe h1 beadlocks re-centered? some good ol eagle alloys maybe?
shock & leaf mounts: suggested brand and place to buy?
front dana 44:
planning on the same, 5.38 gears
locker... with lockable hubs could i just use a spool in the front without effecting street driving and tire wear much? or would a detroit be my best bet? don't feel the need to drop the $$$ on an arb for the front... maybe one day when i'm rich.
which lockable hubs? are the warn kits from advance auto parts (partsamerica.com) recommended? or do you guys recommend another kit?
shafts and joints: i'm still very unfamiliar with the insides of a front axle assembly... i know there are inner and outer shafts, and thats about it... don't fully understand the u-joints and such since i haven't even started tearing down the front axle yet. upgraded shafts recommended for the inners and outers? or is that a waste of money on a front axle? i'm wide open for your suggestions on this topic.
bearings and seals: same question... which brand, where to buy
steering: local shop (masonboroautomotive.com) will be doing my drag link, tie rod, and heim joints... but i'll need to buy the steering arms... which would be the beefiest and best choice to use? don't plan on hydro assist at this time and i doubt i'll look at that as an option in the future since the places i plan to wheel are uwharrie and tellico at best... mostly this will be an overbuilt trail riding rig that plays in mud puddles.
shock mounts and spring mounts: suggested place to buy? suggested brand?
also looking for a way to extend my wheelbase, easily... a few inches maybe... i've seen a few setups where people's front shackles are mounted to a custom front bumper to move the front axle forward a couple inches... any suggestions on that? seems like it would be easier to move the front axle forward than it is to move the rear axle back a few inches....
thanks in advance: i know this is a tough one!
-Erik <--- also looking for ideas about driveshafts
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #2 of 6 Old 08-11-2006, 11:48 AM
jeepnguns
jeepnguns's Avatar
Gears- I only use dana spicer gears easy to set-up and strong.
Bearings and seals- Timken for both although chicago rawhide seals are good also.
Lockers- I only use detroits, what ever you do do not spool the front stteering sucks.
Hubs- get warn Premiums
Have fun and good luck
88 Wrangler
350 Chevy engine vortec heads Holley Pro-Jection
Ford T-18 Tranny
Dana 44s Detroits w/ 5.89s
38" Swamper SX
Lots of other random things and dents
jeepnguns is offline
post #3 of 6 Old 08-11-2006, 06:49 PM
TSEJEEPERS
Wow alot of questions! For gears I would go with Randy's Ring and Pinion. They are spicer brand in Yukon boxes. Get the install kit there too. I would run (and do) the Detroit in the rear. Welded rear or spool would work too depending on how much you drive it on the street. For the disk brake conversion I would run (and do) weldble brackets from speedway motors. They will accept chevy calipers. You should be able to still use the stock wheels off of the Ford. Not sure on the backspacing on the rims but with a 18" wide tire you are going to have to run at least a 10" wheel. There are alot of good springs out there I would stay away from Pro Comp. I am assuming with that big of tire you are going SOA? Wtih your 4 banger right now you may not need a traction bar but when you go to the V 8 you will. The front I would go with the ARB. If you want to run a Detroit or spool in front then you may need to go with a full hydro steering or at least a hydro assist. Warn premiuns for sure for the lock outs. CTMs for the u joints. DOM 2" tubing for the tie rod and drag link.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 6 Old 08-11-2006, 08:56 PM Thread Starter
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
thanks for the help guys... currently sprung over with superlift 3.5" springs and plan to run the BDS once i finish warping these superlifts.... i do have axle wrap but it takes me about 2 yrs of driving/wheeling for it to show (i am on the street most of the time)
question about gearing real quick... jeepnguns, you are running 5.89's? i was thinking that 5.38 was the highest (numerical) gear i could use on the high pinion d44 i'm running up front... so 5.89 is?
post #5 of 6 Old 08-12-2006, 05:28 PM
jeepnguns
jeepnguns's Avatar
For the high pinion the lowest gear set is 5.38 or something like that. I have standard 44s both front and rear so I was able to get down to 5.89.
5.89s with no overdrive sucks on the highway. Off road it is great though.
88 Wrangler
Ford T-18 Tranny
38" Swamper SX
post #6 of 6 Old 08-12-2006, 07:03 PM Thread Starter
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
thanks for clarifying that.... helps a lot since i thought i had found the highest numerical gears to be 5.38 for my setup.
hoping others will chime in with other aspects of the build.... we'll see
-Erik <--- anxious to get this DONE
Dana 30 with ARB locker qurstion "FLUID" gottkts YJ Wrangler Technical Forum 6 01-23-2010 11:38 AM
Clanking Driveshaft "ring" - Dana 35 + NP231 Panici TJ Wrangler Technical Forum 30 05-06-2009 08:37 PM
Blind Date: you meet a girl named "Dana". What do you expect of her? rain-gler Wrangler General Discussion 41 02-10-2009 08:28 PM
dana 44/60 OR dana 44/ford 9" (pics) Michael_94YJ YJ Wrangler Technical Forum 33 06-29-2007 07:44 AM
Build Thread for my Dana 44 and Dana 60 axles... Pics & Questions Inside Big-n-Broke-YJ YJ Wrangler Technical Forum 9 07-11-2006 09:37 AM
