-   -   Help with crank pos sensor (http://www.jeepforum.com/forum/f12/help-crank-pos-sensor-1524862/)
epettit 05-17-2013 09:07 PM
I need a little advise .... I recently put the 4.0 head and fuel injection system (ODB1)on my 4.2 and it has run great. Recently after I have turned it off and let it sit a while it would crank but not start. I would shoot a little freeze it on the Cps and it would fire right up.
I have heard not to run a Cps other then jeep so I purchased a factory CPS from jeep and low and behold it would not start after I went to leave after driving out for lunch.
I was curious why heat causes these to fail and can they be insulated?? Is there another brand to try?
Any help would be appreciated
epettit 05-18-2013 12:12 PM
Any help out there?
laybackman 05-20-2013 07:45 PM
Are you running a header? They generate more heat. Wrap the CKP wiring in several layers of aluminum tin foil and see if that helps.
epettit 05-20-2013 08:15 PM
I am running the factory 4.0 header... But will give it a go. If that does not work I might get an old one from pull apart
idaholtby 05-20-2013 08:25 PM
How long has this rig ran with the new set up? Has it ran fine and now this is a new issue? What model year 4.0L ECM are you using for the MPFI? Sorry for all the questions, just need more info before formulating a possible answer. Oh and for clarity, when you say CPS, you are referring to the crank position sensor and not the camshaft position sensor in the distributer?
epettit 05-20-2013 08:44 PM
Yes it is the crank pos sensor.... The whole setup is out of a 91 Cherokee . It ran for a couple of weeks with no issues but the weather is warming up.
It seams to fail when it's sits for a while and heat soaks the sensor. If you let it cool or hit it with a little freeze it and it fires right up
The time now is 03:00 PM.
