Help! Constant clicking noise as i accelerate - JeepForum.com
post #1 of 14 Old 09-27-2012, 08:55 PM Thread Starter
MatthewS08
Hey fellow wranglers my jeep recently started getting a constant clicking sound when i accelerate throughout all my gears, it gets louder as I get faster in all gears, but in 4th its pretty quiet.
is it the u joints, hydraulic valves, do i need to change the hubs, is it the exhaust I dont knoww what it is has this happened to you before? if so what was it?
MatthewS08 is offline
post #2 of 14 Old 09-27-2012, 09:02 PM Thread Starter
MatthewS08
oh ya someone said it sonded like it was coming from the front axle or near there i think more on the left side
post #3 of 14 Old 09-27-2012, 09:06 PM
yj4trails
I would say u-joint. If it just started all the sudden. You can remove rear drive line if you have a SYE and run in 4wd to check if it is rear. Also make sure you check fluid levels in everything also. But this is where I would start. Good luck.
94 YJ trail jeep...mine
03 TJ small lift n 33's hers
yj4trails is offline
post #4 of 14 Old 09-27-2012, 09:08 PM Thread Starter
MatthewS08
i have a power stearing leak, does that mean anything?
post #5 of 14 Old 09-27-2012, 09:46 PM
jokerchief462
No not really I would isolate the front drive line from the rear driveline to troubleshoot. At least you will know which end. Then you can get to the component level. But the clicking is usually a u-joint.
jokerchief462 is offline
post #6 of 14 Old 09-28-2012, 06:04 AM
Kuntryboy816
Kuntryboy816's Avatar
For Pete's Sake!!! You drive a YJ.... that clicking noise is your teeth rattling!!
On a more serious note, I am having the same issue/noise and found out it was my front passenger ujoint. Check out my 2 vids of what I found. You can hear the clicking in the one vid as I spin the tire. Sorry for the Blair Witch filmography... As I haven't yet figured out how to link Youtube vids on my iPhone and I generally suck at the interwebs....
http://m.youtube.com/watch?feature=plcp&v=AfAwWgze30g
http://m.youtube.com/watch?feature=plcp&v=ZBgvywEhK6k
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is offline
post #7 of 14 Old 09-28-2012, 06:24 AM
Apollo12227
Ujoint or unit bearing/hub
Apollo12227 is offline
post #8 of 14 Old 09-28-2012, 11:47 AM
zeus87gn
1987 YJ Wrangler
What I highlighted above is a direct signal to having internal transmission problems - the counter shaft is in need of repair - probably a bearing - it doesn't do anything but spin with no power being transmitted when in 4th gear -
If it was a u-joint or a unit bearing 4th gear would make no difference
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #9 of 14 Old 09-28-2012, 04:04 PM
Kuntryboy816
Unless its just the tires humming so loud in 4th you can't hear it! ;D
post #10 of 14 Old 09-30-2012, 10:16 PM Thread Starter
MatthewS08
Well now I cant shift into any gears and if I do shift into gear it just grinds the gears making a really loud noise and doesnt move an inch... I'm not sure what it is but I might sell it because iI think the cost of repairs might cost alot, im not sure what it would be.
post #11 of 14 Old 09-30-2012, 11:50 PM
rogerv
I'll have to agree with zeuse on the counter shaft, possibly main shaft bearing.
I've helped my son change 2 ax-5's on his 93.
The first was 3rd gear failure, and the second pic is what was left of the input bearing.
If it's not broke- modify it, so it won't break
rogerv is offline
post #12 of 14 Old 10-01-2012, 04:45 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
This. Definitely.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #13 of 14 Old 10-01-2012, 10:14 AM
zeus87gn
1987 YJ Wrangler
zeus87gn is offline
post #14 of 14 Old 10-01-2012, 11:51 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Agreed, that or the common fifth gear failure.
ratmonkey is offline
1990 , clicking noise , lifted , problem , yj wrangler
Constant Signal Clicking! HELP! True TJ Wrangler Technical Forum 3 05-04-2013 09:57 AM
Help...chirping noise when I accelerate kcjeep1 TJ Wrangler Technical Forum 13 08-19-2011 01:42 AM
Clicking sound when I accelerate on my brand new 2010 Wrangler Sahara bru318 JK Wrangler Technical Forum 7 04-02-2010 03:55 PM
Clicking sound when I accelerate mcdcrook TJ Wrangler Technical Forum 4 11-18-2009 09:16 AM
Loud Clicking Sound When I Accelerate? TJShadow TJ Wrangler Technical Forum 6 08-31-2008 09:49 AM
