Help Catalytic Question - JeepForum.com
post #1 of 3 Old 10-10-2001, 01:50 PM Thread Starter
J33PBA
Newbie
I have imported my Jeep 95 4.0L to the UK
from Saudi Arabia. Just done the emmision test and it failed. It has no cat and failed on CO % VOL. Jeep runs great, but have to pass the test, so I have bought a High Performance Cat from Random Tecnology.
There is no sensor and is not required with this cat as I understand. When I fit this Cat is it going to pass. Lets hope so !
Results of CO % were as follows on failed test.
Fast Idle 1 (2500 RPM) Limit Mine
0.30 0.97
Fast Idle 2 " 0.30 1.24
Natural Idle 0.50 0.63
It passed on HC ppm VOL and Lambda.
Many thanks
J33PBA is offline
post #2 of 3 Old 10-10-2001, 02:39 PM
Nightclaw
Well, given your numbers and what is needed to pass, you should have no problem passing with the RT cat. Just make sure you drive about 20-25km right before your test to make sure the cat is heated up real good, has burned off any lingering petrol soot and is doing it's job. Good luck!
Nightclaw is offline
post #3 of 3 Old 10-10-2001, 02:58 PM Thread Starter
J33PBA
Newbie
Many thanks Nightclaw. I'll sleep better tonight !
J33PBA is offline
Catalytic Converter Question? ChickenStomp YJ Wrangler Technical Forum 6 06-19-2009 04:21 PM
catalytic converter question southernr Wrangler General Discussion 11 08-26-2008 08:38 PM
Catalytic question JeepKat24 TJ Wrangler Technical Forum 5 09-30-2006 02:38 PM
Catalytic converter question boomhower YJ Wrangler Technical Forum 6 07-11-2005 07:28 PM
Catalytic Converter Question OlllllllO YJ Wrangler Technical Forum 10 09-24-2003 06:21 PM
