Help can't get jeep to start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Help can't get jeep to start
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 05-15-2013, 02:57 PM   #1
Badyj7
I have a 1990 yj I put a 95 dash and dash harness a 95 tilt column a 95 yj engine harness and body harness and a 4.0 out of a cherokee and I swapped in a 95 tank assy when u turn the key the fuel pump comes on the check engine lamp lights up but it will not turn over help
Badyj7 is offline   Reply With Quote
Unread 05-15-2013, 08:45 PM   #2
Badyj7
Help I'm running out of things to try has to be a simple wire fix
Unread 05-16-2013, 11:50 AM   #3
AM92
1992 XJ Cherokee
Is it turning over?
AM92 is offline   Reply With Quote
Unread 05-16-2013, 11:56 AM   #4
CrawlingForward
Rookies Happen.
CrawlingForward's Avatar
You gave us a good amount of information to start with, but completely filling out your Jeep info in your profile will also help a lot.
First things first, give us a *detailed* summary of what goes on when you turn the key.
Does it spin, but not spark?
Do you get a clicking?
Does it fire, but won't fully start?
Have you tested to see if you're getting spark?
Have you tested to see if you're getting fuel?
Have you done a compression check?
Does the CEL turn on and off, or does it stay on?
If it stays on, what error code is it giving you?
We need more information before we can help.
(FYI, this isn't really *advanced* Jeep tech. That's more for advanced fab and unusual conversions and specialty projects. This should be in YJ tech. A mod can move it.)
My Other Jeep Is A Jeep - Crawlingforward's Jeep-Related Adventures
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
- North Shore Jeep Club -
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline   Reply With Quote
Unread 05-16-2013, 12:55 PM   #5
Imped
Imped's Avatar
Solid thread.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote
Unread 05-16-2013, 01:03 PM   #6
CrawlingForward
Rookies Happen.
Solid thread.
Eh, we all gatta start somewhere. The whole "forum"/"troubleshooting" thing took me a bit to learn too, so I figure I'll try and pay it forward by teaching someone else how to ask for help.
My first time on the forum I was so excited that I figured out my oil pressure issue that I searched for "low oil pressure" on the forum and added my findings to all of them, figuring it would be useful for someone's search later on, not realizing many of the threads were like 3 years old and flooding people's inboxes, ha ha ha.
Imped, can you think of any other questions the OP should be answering.
Unread 05-16-2013, 02:09 PM   #7
Old4X
1990 CJ7
What are you using for an underhood harness? Did you install the PDC from the donor jeep?
Rust free YJ for sale. Need more room in barn.
Old4X is offline   Reply With Quote
Unread 06-04-2013, 04:33 PM   #8
Badyj7
Does it spin, but not spark? Yes
Do you get a clicking?yes
Does it fire, but won't fully start?no
Have you tested to see if you're getting spark?yes if I put a jumper to the pos and tap the neg I get spark
Have you tested to see if you're getting fuel?yes it is and the injectors are pulsing
Have you done a compression check?no
Does the CEL turn on and off, or does it stay on?yes it does not showing any codes besides the ac and code55(done)
I put a yj harness in it , it clicks fuel pump primes I've check and have all the needed power to the computer any ideas I really appreciate the help
Unread 06-04-2013, 04:35 PM   #9
Badyj7
Also I have replaced the crank position sensor the complete distributor the coil and the computer
Unread 06-04-2013, 05:23 PM   #10
idaholtby
What year Cherokee 4.0L engine did you use? Meaning, what do you have installed for a Fly Wheel (year and drivetrain very important)?
idaholtby is offline   Reply With Quote
Unread 06-04-2013, 05:38 PM   #11
Badyj7
Motor is out of a 95 grand Cherokee trans and flywheel from a 90 xj Cherokee aw4
Unread 06-04-2013, 06:19 PM   #12
idaholtby
Damn, I hoped this wasn't the answer to the question I asked. I really didn't. Your flywheel is not compatible with the rest of your drivetrain that you selected. It will not provide the correct pulses via the CPS for a OBDI equipped system that you have melded together. You need a fly wheel from a 4.0L from 91-95.
Unread 06-04-2013, 07:31 PM   #13
Badyj7
Let me go back and check for sure what year it was I know it has the sensor ring around it for the cps
Unread 06-04-2013, 07:48 PM   #14
idaholtby
Many different years have different tone rings on the Fly wheel depending on the application. I certainly hope this is not your case. I hope that a '90 fly wheel is not supplying sensory info to a OBDI brain. Please report back your findings. Your rig is certainly a Frankenstein and I would like to know the outcome (as I suspect many others trying to do the same).
Unread 06-04-2013, 07:52 PM   #15
Badyj7
Ok I went back and found the PayPal receipt it was from a 2000 Cherokee I did a 6cyl. Conversion and updated everything to 94-95 stuff wanted to do the auto I thought the aw4 would work so what your saying is I need a flywheel from a 94 aw4 ?
