Help on bypass (merged) - JeepForum.com
post #1 of 13 Old 06-02-2013, 09:43 PM Thread Starter
Jeepals
Trying to so nutter bypass to 1989 wrangler 4.2l, I cannot figure out what happens to the purple wire. The orange ends up turning light green when going to ignition module, does purple change color or what?
Jeepals is offline
post #2 of 13 Old 06-04-2013, 12:38 PM Thread Starter
Jeepals
Purple wire
Purple wire from distributor, what color does it become going into ignition module!? I know orange wire switches to light green but can't figure put which is purple.
Jeepals is offline
post #3 of 13 Old 06-04-2013, 06:26 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
From Joe Peters and well stated. Sounds harsh but just makes sense:
“Let’s play a game.
You pretend that you are the only one that knows what year/engine/model, etc that you are asking about.
We will all pretend you never asked a question until you provide at least the bare minimum of information about your vehicle”.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 13 Old 06-05-2013, 01:21 AM
Fins
1980 CJ7
I'll take 89 Wrangler with 4.2L for 500. Oops, wrong game...
Fins is offline
post #5 of 13 Old 06-05-2013, 09:31 AM Thread Starter
Jeepals
Ding, ding! We have a winner! Haha! Sorry, that would've made it to easy on it. Yes, it's 89 wrangler 4.2l 258. As you probably suspect too, I'm trying to do the bypass. Again, sorry for the lack of info. I was at work trying to type quick so I didn't get caught on the phone.
Jeepals is offline
post #6 of 13 Old 06-05-2013, 01:14 PM
NonRubicon
Here is a link to check out: http://home.sprynet.com/~dale02/ignmods.htm
Click the images to see more info.
Essentially, the purple wire from the distributor gets spliced into the purple wire in the 4-wire ICM plug. The correct wire on the ICM side of the connector will be paired with an empty slot on the harness side of the connector.
Optionally, the empty slot in the 4-wire plug is where you can plug the purple wire from the dizzy into the ICM, provided you use the right weatherpack pin. So, instead of going around the 4-wire connector, you make use of the connector like the factory CJ setup. This is how the computer bypass is done for the Howell TBI kit and lets you disconnect and remove/replace the ICM later without cutting and resplicing wires.
NonRubicon is offline
post #7 of 13 Old 06-05-2013, 03:20 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
So you got busted by US instead!! LOL.
post #8 of 13 Old 06-05-2013, 06:09 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to YJ Forum and duplicate threads merged.
Wheelin98TJ is offline
post #9 of 13 Old 06-06-2013, 04:12 PM Thread Starter
Jeepals
Lol! Yes, I think I'll take my chances with the boss next time. He might be a little more lenient then you guys.
Jeepals is offline
post #10 of 13 Old 06-06-2013, 04:15 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Ah, we're more fun......
post #11 of 13 Old 06-06-2013, 04:16 PM Thread Starter
Jeepals
Thanks a lot nonrubicon appreciate the help and the diagram
Jeepals is offline
post #12 of 13 Old 06-06-2013, 05:32 PM Thread Starter
Jeepals
Well, of course! Nothing compares to the pranksters in the jeep nation. Haha
Jeepals is offline
post #13 of 13 Old 06-07-2013, 02:52 PM Thread Starter
Jeepals
Got bypass done and now the idle is real slow. Ive adjusted it on carb but stays a slow idle. What could be causing this? Any solutions?
Jeepals is offline
