Help buying Tie Rod parts - JeepForum.com
post #1 of 8 Old 07-08-2013, 09:55 AM Thread Starter
RUBE1975
Hey all, so my 93 4.0L desperately needs new tie rods. I dont have the cash to send it out so im doing the work myself. Im pretty comfortable tackling this work but im not 100% im ordering all the correct parts. Here is what I think ill need.
http://www.jeep4x4center.com/tie-rod...-52005741.html
http://www.jeep4x4center.com/tie-rod...-52005740.html
http://www.jeep4x4center.com/tie-rod...-52006602.html
http://www.jeep4x4center.com/tie-rod...-52005739.html
Are there any parts im missing? I have a decent set of tools; including a pickle fork and torque wrench, but is there anything else I need? Grease?
If someone has a wirte up on doing this that would be awesome. Thanks
RUBE1975 is offline
post #2 of 8 Old 07-08-2013, 03:01 PM
ionakana
Grand Poobah
ionakana's Avatar
Here's a diagram of the steering. Don't buy those cheap parts you have links too, you'll be buying them again very soon. Get Moog parts and yes, you need to Grease them. They're pretty simple to replace, you will need an alignment when you're finished. You should just need #13, 14, 15 and 17 and like I said, buy Moog parts, not the ones I have linked to either.
http://www.cyberjeep.com/yj/parts/st...ement-parts-yj
Psalm 14:1
Live in Georgia? click here-->
ionakana is offline
post #3 of 8 Old 07-09-2013, 09:01 AM
YJScrounge
I installed Luke's links, links.com. It's an adjustable replacement kit and rebuilds what you have. You need a grinder to do the job and avoids having to get an alignment. This kit started for the ram pickups as they eat tie rods. I put these on my truck and YJ. The only issue I had was they rubbed against the stock wheels. You'll be ok if you have offset rims. They run about $50 each. Check them out...
YJScrounge is offline
post #4 of 8 Old 07-09-2013, 09:19 AM
roadyrob
1987 YJ Wrangler
rockauto has great prices on moog tre's.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #5 of 8 Old 07-09-2013, 05:59 PM
dcocch
You'll spend about $200 getting Moog parts, definitely worth it (assuming you get new sleeves and everything).
You can do your own alignment afterwards! It takes 30 min and saves you $50! There are lots of write-ups on it.
dcocch is offline
post #6 of 8 Old 07-09-2013, 08:50 PM
jokerchief462
Once you get whatever your replacements are clean up the old ones and put new cotters pins with them in the old boxes and keep for trail spares in your trail gear box. They will save you tons of money one day.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #7 of 8 Old 07-10-2013, 10:48 AM
dcocch
That is a good point. I don't go wheeling but I would have put mine up in the classified for free if I would have thought about that 2 months ago.
dcocch is offline
post #8 of 8 Old 07-10-2013, 11:17 AM
voz
I replaced all my front end steering items with MOOG Parts. Great investment..
Moog's site will give you part numbers needed, then shop around,
Ebay & Amazon is where I got all my parts.
VOZô
voz is offline
