Help! Broken turn signal arm (wiper control) - JeepForum.com
post #1 of 9 Old 10-27-2007, 10:41 AM Thread Starter
mbg75
i have a 95 wrangler. My turn signal arm broke off inside the column. it slides back in, but i now have no wiper control except mist (when i turn the inner piece forward). The outter part of the arm has a metal rod which goes into the column to turn on the wipers, This is what broke off.
Are the parts avaliable?
What is involved with changing them?
thanks in advance for help!
mike
mbg75 is offline
post #2 of 9 Old 10-27-2007, 10:56 AM
90yjkrawler
I had this happen once. Go to the dealership and get a new control arm, it's only like $15. Pull off your steering wheel and then the horn button and then there will be a few screws holding in the actual wiper and turn signal controls. Fish out the last piece of the old arm, put it all back together and slip the new arm in.
Until They All Come Home!
90yjkrawler is offline
post #3 of 9 Old 10-27-2007, 10:58 AM Thread Starter
mbg75
wow, that was fast!
Thank you for the info!
mbg75 is offline
post #4 of 9 Old 10-27-2007, 11:15 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Here is a good link about taking the column apart. It is for an older one but they did use the same parts over the years.
http://www.epiccomputer.com/dale/jee...tilt/tilt.html
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 9 Old 10-27-2007, 02:20 PM
bcwheeler
There is no need to take the column apart.. since you cant reach into the hole and grab the broken off peice thats still inserted into the column, I drilled a tiny hole into the peice and threaded in a screw (make sure it gets a good bite) then i could grab the screw with a pair of pliers and pulled the broken off peice out. The new lever simple pushs right in.
bcwheeler is offline
post #6 of 9 Old 10-27-2007, 02:21 PM
bcwheeler
Also I got a new lever from the junkyard for 5$ out of a 91ish chevy pickup, they use the exact same lever.
post #7 of 9 Old 01-11-2010, 07:46 PM
SydPat2009
Thanks bcwheeler, your advice was perfect. drilled into the broken piece, got a screw into it and pulled it right out. Took about 10 mins. Got the new part on Autozone.com for $10.99. Awesome.
SydPat2009 is offline
post #8 of 9 Old 12-17-2011, 01:21 PM
SamzJeep
Mine broke off on my '90 YJ. I can't get the broken piece out! I tried to drill it out and use a screw to pull it out, but that didn't work. so I tried an easy-out and that damn thing broke off inside the hole I drilled. Now I can't redrill it. I pulled the column off to try to get the piece out. I got everything off (hanging from the wires) but I still can't get the piece out. it's really in there good. Any ideas? I'm I doing something wrong? I thought it just pulled out? Does it have to be lined up or something? Any help would be appreciated. Please someone/anyone respond! :-) Thanks in advance.....
SUPPORT OUR TROOPS
SamzJeep is offline
post #9 of 9 Old 12-17-2011, 02:36 PM
DAVE4273
It should just pull out if you can get a hold of it, the new one just slides in. Autozone has em hanging on the shelf in the HELP section. Funny too its the exact part.
David
DAVE4273 is offline
Broken turn signal lever, Need to turn OFF hi-beams Tulsachokehold YJ Wrangler Technical Forum 16 12-10-2014 12:39 AM
How Do You Fix A Broken Turn Signal/wiper Lever twokids YJ Wrangler Technical Forum 17 10-31-2014 05:15 PM
turn signal wiper arm control Neighborbill YJ Wrangler Technical Forum 0 04-22-2009 06:32 PM
Turn signal/wiper control interchange czjeeper YJ Wrangler Technical Forum 5 11-30-2007 06:17 AM
wiper/turn signal lever StuckInMud94 YJ Wrangler Technical Forum 3 08-06-2005 10:49 AM
