Help with Brake Booster/ Master Cylinder - JeepForum.com
post #1 of 14 Old 10-21-2008, 04:02 PM Thread Starter
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
I just got a new brake booster with the master cylinder and I don't know how to install it. can anyone help me? Is there any directions or a write-up?
Thomas
-1987 YJ
Tompatt is offline
post #2 of 14 Old 10-21-2008, 05:00 PM
VT2BAD4U
Get a service manual if you plan on working on your vehicle. Lots of information that will assist you in doing repairs.
Glad to see you are taking an interest in working on your vehicle. BUT, if you are stumped as to how to do this fairly easy job, it is best if you get someone with some posative experience to do it for, or with you. It's a major safety related and potental liability issue.
VT2BAD4U is offline
post #3 of 14 Old 10-21-2008, 05:14 PM Thread Starter
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
lol. its in the Haynes? i always forget to check there first. ha. thx for the info. workin on jeeps is fun stuff. xD
Thomas
-1987 YJ
Tompatt is offline
post #4 of 14 Old 10-25-2008, 12:05 PM Thread Starter
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
i wanna do this by myself or with my dad. i just don't want to take it to the shop to spend extra money just to put it on. has anyone else put theirs on by their self? how easy is it?
Thomas
-1987 YJ
Tompatt is offline
post #5 of 14 Old 10-25-2008, 01:12 PM
tonythehazelnut
I've replaced my master cylinder with one of my friends. Replacing the master is easy, so don't fret. You might want to have an extra set of hands to hold stuff, and you'll need it to bleed the system. Removing the old master is just a matter of loosening the brake line fittings that screw into the side of the master and removing the nuts that hold it to the brake booster. as far as removing the booster goes, I've never done that before. But back to the master... First, empty the reservoir of as much fluid as possible. You don't want it staining your driveway or eating the paint away on your truck. Second, remove the fittings from the side of the master. You may need a special wrench to do this. Third, use a ratchet to remove the nuts that fasten the master to the booster, and pull the master toward the front of the truck. The master should slide straight out. Keep the old fittings if they came off, you'll need new ones from the parts store... If you need new fittings, sometimes it's cheaper to buy new sections of lines that come with two fittings than it is to buy just the fittings. Anyway, next you want to remove the brake booster. I've never done this, so I'm just gonna skip to the installation of the new master. You want to bench-bleed the new master cylinder. I didn't do this, and I think I still have some bubbles in my system. So bench-bleed your new master. It should be just a matter of filling the reservoir, and and pushing the piston back and forth with a screwdriver to get the new air bubbles out. Your master might have come with a bench-bleeding kit, so if it did, follow the directions. Anyway, after the master is bled, hook the hard lines from the proportioning valve (the lines from the old master that you just disconnected) up to the new master, and re-bolt the master to the booster. Before you do this, make sure the push-rod is all the way out. So just pull it out of the booster, and slide the master over it and bolt it in. Then bleed the system. Project done.
Built Not Bought #482
AN ARMED SOCIETY IS A POLITE SOCIETY
tonythehazelnut is offline
post #6 of 14 Old 10-25-2008, 01:31 PM Thread Starter
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
thx alot dude. one question tho. in the haynes manual there is a wire going to where the brake lines meet right under the master. its like a 2 prong plug. what is that for because i don't have a wire hooked up to that...
Thomas
-1987 YJ
Tompatt is offline
post #7 of 14 Old 10-25-2008, 01:36 PM Thread Starter
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
heres a pic.. that lil red plug..
Thomas
-1987 YJ
Tompatt is offline
post #8 of 14 Old 10-25-2008, 04:28 PM Thread Starter
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
nvm i figured out.
so bench bleed first while its off or should i do it while its on the jeep? the master cylinder and the brake booster were attached when i got it. so detach the master cylinder then bench-bleed? put it bak on the brake booster then put it all in the jeep. and hook up the lines? i have to bleed the brakes too?
Thomas
-1987 YJ
Tompatt is offline
post #9 of 14 Old 10-26-2008, 01:18 AM
tonythehazelnut
Okay, so they were attached... that may make it somewhat easier, I would imagine... I think I would bench-bleed the master with the booster attached, as long as you can hook it up that way. That way you can bench-bleed it using the push-rod instead of a screwdriver. Do it in a vice, if you have one. Clamp it so it's level and bleed it, so you get those last few air bubbles out. And I would bleed the entire system as well. Brake fluid is cheap you don't want to chance having air in the system... I would say that's the best way of doing it.
post #10 of 14 Old 10-26-2008, 06:25 AM Thread Starter
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
Thx. I don't have a vice, but Ill think of a way. I have to get a shopping list made up. Lol.
1.Bench Bleeding Kit
2.Brake Fluid
Thomas
-1987 YJ
Tompatt is offline
post #11 of 14 Old 10-26-2008, 04:45 PM Thread Starter
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
While i was looking at all the brake related components. i saw that this was unplugged (the red plug). does it matter if it is plugged in or not?
Thomas
-1987 YJ
Tompatt is offline
post #12 of 14 Old 10-27-2008, 08:37 AM
muddy93
1987 FSJ Wagoneer
I could be wrong, but I think that's the plug for the brake warning light on the dash, the one that comes on when there is a problem with the brakes, like if you blow a line, and loose fluid preasure.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #13 of 14 Old 10-27-2008, 01:51 PM Thread Starter
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
hmm. i don't even have a light for that i don't think. lol. any more ideas on what it could be?
Thomas
-1987 YJ
Tompatt is offline
post #14 of 14 Old 10-27-2008, 02:03 PM
Wif
Wif's Avatar
Originally Posted by Tompatt View Post
While i was looking at all the brake related components. i saw that this was unplugged (the red plug). does it matter if it is plugged in or not? ...
Under the switch is a shuttle valve that will operate if either the front or the rear brake fluid circuits lose pressure. It's part of the dual circuit braking system.
There should be a warning lamp on the dash that will light up if the switch is operated due to a pressure issue. To test, just bridge the contacts, turn on the ignition and look at the dash .. does a lamp come on. If not, then maybe the lamp has blown.
By default the lamp should never come on (unless it's part of the self diagnostics on start up .. I can't remember)
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
Master cylinder/Brake booster question Smitty1 YJ Wrangler Technical Forum 0 05-10-2009 08:32 AM
I need to replace my master cylinder & booster - Will This Work!!! mandng0 YJ Wrangler Technical Forum 23 04-01-2009 02:42 PM
Vanco Brake Master Cylinder/Booster goatboy YJ Wrangler Technical Forum 5 04-26-2008 10:28 AM
95 Brake Master Cylinder CjinPA YJ Wrangler Technical Forum 3 07-26-2006 01:05 AM
brake booster and master cylinder sandman'sjeep YJ Wrangler Technical Forum 3 06-28-2006 08:51 AM
