HELP the ax-5 clip and collar problem - JeepForum.com
post #1 of 4 Old 04-08-2010, 05:51 PM Thread Starter
DDove
Hello, Im doing the colloar on my ax-5 everything has gone perfect. I knew it would not last. I took the back of the trans off and sure enough the gear was loose. I took the gear off to inspect and now I don't remember which way it goes on, and I cant find a picture. Also, I found a metal ball kind of like a ball bearing where does that go. My last question, The shifter detent up where the actual sift rod goes there are two of them. I removed them and one looks great and goes in and out fine, the other is slow to go in and out and is alot smaller???? Thanks for your help
DDove is offline
post #2 of 4 Old 04-08-2010, 05:54 PM
77j20
1977 J-Series Truck
I can't recall which way the gear goes its been about a year since I had it apart. The little ball probably goes into one of those torx plugs on the side of the tranny. When I pulled mine apart and removed those torx plugs there was a spring and a ball that rides on your shift rail.
1977 J-20 TeamRushed AMC 401, TH400, D44 front, D60 rear, 33x12.50R16.5 Mud Terrains, SOA, rear shackle flip.
77j20 is offline
post #3 of 4 Old 04-08-2010, 05:58 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by DDove View Post
Hello, I'm doing the collar on my ax-5 everything has gone perfect. I knew it would not last. I took the back of the trans off and sure enough the gear was loose. I took the gear off to inspect and now I don't remember which way it goes on, and I cant find a picture. Also, I found a metal ball kind of like a ball bearing where does that go. My last question, The shifter detent up where the actual shift rod goes there are two of them. I removed them and one looks great and goes in and out fine, the other is slow to go in and out and is alot smaller???? Thanks for your help
The gear goes on the output shaft like the one in the top of this picture.
The ball is probably the one shown here, in the cluster gear shaft.
Here is a bigger picture of the cluster gear shaft.
Look here for more AX-5 pics.
Transmission pictures by meanmax - Photobucket
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 4 Old 04-08-2010, 06:49 PM Thread Starter
DDove
Thanks for the help. Whew, this is my first time ever tearing apart a tranny. I must say that this is a repair that anyone can do. Again, thanks
DDove is offline
AX-5 5th gear clip & collar repair without trans removal Mean Max YJ Wrangler Technical Forum 142 07-18-2016 02:43 PM
Rear axle bearing problem on dana 35 W/O c clip bilwil YJ Wrangler Technical Forum 6 04-03-2012 06:02 AM
Anyone find a good solution to rear window clip problem? bantam JK Wrangler Technical Forum 6 08-19-2007 11:31 AM
Dana Super 35 C-Clip Problem harpo1 TJ Wrangler Technical Forum 8 03-20-2007 09:33 PM
dana 35 spider gears... c clip vs non c clip Big-n-Broke-YJ YJ Wrangler Technical Forum 2 08-03-2006 09:00 PM
