Help with 95 YJ Universal Joint - JeepForum.com
post #1 of 13 Old 02-14-2010, 03:20 PM Thread Starter
claygarland
I heard some noise when shifting and decided to look at my u-joints. The one connected to the rear drive shaft was in pretty bad shape. I went to autozone and got a replacement but it doesn't seem like it fits correctly. Its a cheapy Neapco PN 1-0153. I have some pictures of it sitting in the location where its supposed to fit. If you can identify if its the right part or not and what would be a not too expensive correct U-joint to use I would appreciate the help.
claygarland is offline
post #2 of 13 Old 02-14-2010, 04:46 PM Thread Starter
claygarland
Any help would be awesome!
post #3 of 13 Old 02-14-2010, 04:48 PM
champelite210
You need a combination u joint 1310 on one side 1330 on the other.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #4 of 13 Old 02-14-2010, 04:51 PM
wildman90
without knowing more about your lift and /or axle it is hard to tell. it APPEARS as though you have a 1330 size yoke on the axle. it is possible that you also have the wrong ujoint in the box.
nothing i cant do--i'l pay myself $50/hr labor!!
the only thing you cannot do, is that which you have already accepted defeat!
many people search for god in the eleventh hour, only to die at 10:30
wildman90 is offline
post #5 of 13 Old 02-14-2010, 05:19 PM
machinehead131
95's have a bigger driveshaft u joint. 1330. Get the correct one, I do not think you need a combination just a standard 1330 joint.
Looking for TJ Rear Flares, if anyone has any please PM ME.
Thank you.
machinehead131 is offline
post #6 of 13 Old 02-14-2010, 05:32 PM Thread Starter
claygarland
Thanks
I pulled this info off a pdf from the Neapco site im going to go back and purchase the other part that matches the chart. Here's the info I looked at:
part num
1-0134
yoke lock up
3.219(o)
3.622(o)
BD
1.063
Type
round
Converts part Nos.
1-0153
2-4800 Im guessing this is going to be the correct one
U-joint type
Spicer(1310)
Spicer(1330)
post #7 of 13 Old 02-14-2010, 06:23 PM
FarmBoy
My 95 rear driveshaft takes 2 different u-joints. The one at the pinion is different from the slip yoke end.
-Jeff
1995 YJ 4 cyl auto, 2" BDS springs, BDS shocks, and 1/2 lift boomerang shackles. 31" BFG Mud Terrain.
FarmBoy is offline
post #8 of 13 Old 02-15-2010, 05:19 PM Thread Starter
claygarland
Ends up it was a spicer 1310-1330 conversion...It had the 1310 in it darn you PO
post #9 of 13 Old 02-16-2010, 09:39 AM
RUN4CVR
I just ran into the same exact problem this past weekend. I was also planning on doing the U-joint strap to U-bolt conversion.
Its a stock 94 YJ, so i couldn't understand why the 1310 set up was too small.
I'll give the 1330 a try as well.
RUN4CVR is offline
post #10 of 13 Old 02-16-2010, 10:45 AM
bill8bud
Well the good thing is the spicer is a better part than the Autozone one.
bill8bud is offline
post #11 of 13 Old 02-16-2010, 01:09 PM
CreepyCrawler95
dont hate neapcos haha im running 5 of them on all driveshaft positions. too bad dad wouldnt fork out some cash for some super joints haha
CreepyCrawler95 is offline
post #12 of 13 Old 02-16-2010, 01:43 PM
scramblered
I learned one thing from helping my son with his F150... take the old U-joint with you if you can. I found out the hard way that Ford is famous for throwing a couple of different sizes in their stuff for no rhyme or reason. It just saves an extra trip to the parts store if you take the old one. Dave
scramblered is offline
post #13 of 13 Old 02-20-2010, 06:12 AM Thread Starter
claygarland
Thats exactly what I did and ususally works but somehow the PO had fit smaller parts than what were needed in there...Oh and I did buy the neapco equivalent of those spicer sizes I listed hehe they were cheap which is good for the jeep.
'95 , u-joint , universal joint , yj.
front diff universal joint bartolo YJ Wrangler Technical Forum 1 06-02-2009 05:21 PM
'97 TJ rear universal joint caps cybervyk TJ Wrangler Technical Forum 3 04-20-2009 07:35 PM
universal Universal Joint question likely universally asked.... firefighter315 YJ Wrangler Technical Forum 14 01-23-2009 01:04 PM
Axle universal joint 99bluewrangler TJ Wrangler Technical Forum 6 04-17-2007 04:15 PM
Universal Joint Q's for the D30 CanukYJ YJ Wrangler Technical Forum 6 06-11-2004 10:37 PM
