Help! 89 Yj bucking and power loss. - Page 2 - JeepForum.com
post #16 of 27 Old 03-20-2013, 10:42 AM
Que89YJ
Running better cold is a big clue. The system goes closed loop when it warms up and starts using the O2 sensor to set air fuel. Check the O2 sensor and the exhaust manifold for cracks especially around the collector tubes and for loose or bolts or gasket leaks. You can experiment and disconnect the O2 sensor and it will run in a default mode for the calibration and see if it makes a difference. The other thing we have that is different then the others is the egr. It is the pipe setup under the manifold going to the exhaust. Look for any leaks on the pipe.
Que89YJ is offline
post #17 of 27 Old 03-20-2013, 10:44 AM Thread Starter
duckhunter17
Thanks ill get my meter out this evening and check ill let yall kno
duckhunter17 is offline
post #18 of 27 Old 03-21-2013, 06:14 AM
Que89YJ
Did you get it fixed? Was the O2 bad?
Que89YJ is offline
post #19 of 27 Old 03-21-2013, 09:38 AM Thread Starter
duckhunter17
No man didnt have time though I will this weekend got to fix my tailights when I press my brake my reverse lights come on and I got a ticket( darn small town cops). But I suspect that it is the o2.
post #20 of 27 Old 03-21-2013, 12:39 PM
Que89YJ
I hope it's a fixit ticket in Mississippi. Keep us posted.
Que89YJ is offline
post #21 of 27 Old 03-22-2013, 09:40 AM Thread Starter
duckhunter17
Well they issued a work order to get it fixed in 7days then no ticket
post #22 of 27 Old 03-22-2013, 09:46 AM Thread Starter
duckhunter17
Im still having the power loss though changed tps yesterday and no difference think I might cut the cat out today anyone know how much louder it will be
post #23 of 27 Old 03-22-2013, 11:08 AM
schaef89
Did you adjust the tps when you installed it? It's not plug and play like later jeep models
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #24 of 27 Old 03-22-2013, 11:15 AM Thread Starter
duckhunter17
No I didnt adjust it didnt know that I could you think that would help.
post #25 of 27 Old 03-22-2013, 11:39 AM
Que89YJ
tps, isa, wot, and fuel psr. all must adjusted when replaced. You need a meter and the service manual.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #26 of 27 Old 03-22-2013, 11:47 AM Thread Starter
duckhunter17
What is isa and wot
post #27 of 27 Old 03-22-2013, 01:19 PM
schaef89
Idle speed motor and wide open throttle sensor
schaef89 is offline
bucking , jeep , jerking , YJ
