Help! 89 Yj bucking and power loss. - JeepForum.com
post #1 of 27 Old 03-17-2013, 11:55 PM Thread Starter
duckhunter17
Hey guys, got my first jeep bout three months ago ( 1989 yj 2.5l. Manual) and have had little trouble since but about a month ago cranked her up one day and took off and when I accelerated it acted like I wasn't pressing the gas at all, so I pressed it to the floor , still no response let off of it a little and sped up , pressed to speed up again and the jeep bucked forward and made a terrible noise from the engine compartment like a popping noise, any help is appreciated, first time using a forum just need help, also I replaced the fuel injector that I was told could be it but to no avail. Thanks ya'll
duckhunter17 is offline
post #2 of 27 Old 03-18-2013, 08:53 AM
Siva283
You posted this twice. Have you checked your codes yet? Do you know how?
Ask me how I know...
Siva283 is offline
post #3 of 27 Old 03-18-2013, 09:49 AM
jokerchief462
I got an 89 and can't get any codesout of mine. Sounds like one of two issues. Fuel starvation or ignition. You need to really check and see how the fuel system is. First a fuel filter change and then you are going to have to check the pulugs cap rotor and wires. While the plugs are out you should do a hot (engine temp normal) compression test. Once assembled start it back up your timing should be at 8 degrees BTDC. Clean up or replace what you don't like and go from there let us know how it progresses. It could just be a a tune-up
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 27 Old 03-18-2013, 09:50 AM Thread Starter
duckhunter17
Sorry didnt know I posted it twice , but I didnt kno u could check codes on an 89, is it obd1 ,if so where is it , its really bugging me though thanks
post #5 of 27 Old 03-18-2013, 10:05 AM Thread Starter
duckhunter17
Thanks joker just changed plugs didnt change wires though guess I should though you think I should do a fuel pressure test for the pump but I am lost on timing so I dont know how to do that thanks
post #6 of 27 Old 03-18-2013, 10:25 AM
Que89YJ
Timing is computer controlled. No fault codes on the renix TBI system. Make sure what you are hearing is backfiring and not missing. Backfiring is definitely timing related. Links for the FSM. Download them. If you don't have a meter get one. Backfiring is Distributor (and pickup sensor sold as a unit) or timing chain. You check the chain slack by rotating the crankshaft pulley counter clockwise until the rotor starts to move and then clockwise. You shouldnt see more thean a couple inches of movement.
Here is a link for the FSM. Follow the adjustments on all the sensors.
http://dl.dropbox.com/u/40590346/87-88%20YJ%20Jeep%20Wrangler%20FSM%20manual.pdf
http://dl.dropbox.com/u/40590346/1990%20Jeep%20Factory%20Service%20Manual.pdf
Que89YJ is offline
post #7 of 27 Old 03-18-2013, 10:47 AM Thread Starter
duckhunter17
Icant tell whether its backfiring or missing but the noise is really loud oriellys told me it could be the tps but ill try what u told me thanks for.the links
post #8 of 27 Old 03-18-2013, 12:10 PM
Que89YJ
Loss of power can be a few things. Catalytic coverter blocked would be another good one to check out. Backfiring is very specific that is why I asked.
Que89YJ is offline
post #9 of 27 Old 03-18-2013, 12:23 PM Thread Starter
duckhunter17
Might have to check cat out then and does anyone know where my tps is on my jeep think I might check it out to pic would be great but not neccesary . Thanks
post #10 of 27 Old 03-18-2013, 12:42 PM
jimsahm
Drop your tank and clean it out... I had the EXACT same issue. Mine would idle fine, travel low speeds fine... go to accellerate on the highway and it would start to buck... finally die out (float bowl was empty)... I tried everything... new fuel pump, plugs, wires, etc...
The "sock" at the bottom of the fuel pickup tube was overgrown with crap... Also, for some reason the pickup tube itself was full of what looked like rust particles... It's not a tough job, but certainly the tank must be very close to empty....
Cheers,
Jim
jimsahm is offline
post #11 of 27 Old 03-18-2013, 01:19 PM Thread Starter
duckhunter17
Thanks jim plan on doinh some work on it yhis weekend just one more thing im gonna try this weekend thanks ya'll
post #12 of 27 Old 03-20-2013, 10:40 AM Thread Starter
duckhunter17
Aight guys so yesterday i did some things to see what would help so i changed my plug wires,fuel filter (filthty) , distributer cap and rotor and it seems to have got rid of the bucking problem but still have power loss any suggestions now, but someone told me it could be either the tps or cps no clue?
post #13 of 27 Old 03-20-2013, 11:20 AM
schaef89
Does it act up when the engine is cold or when the engine is warm? or both?
If it does it when the engine is warm and doesn't do it when the engine is cold, it's most likely a sensor. If it's both then it's probably something that isn't sensor related
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #14 of 27 Old 03-20-2013, 11:25 AM Thread Starter
duckhunter17
Actually runs better cold dont know why but it does
post #15 of 27 Old 03-20-2013, 11:27 AM
schaef89
Start running sensor checks with a multimeter per the FSM Que gave you.
The list of sensors is: TPS, WOT, ISA motor, O2, CTS, MAT (any other I'm missing from the FSM)
You'll find one is wrong most likely
schaef89 is offline
bucking , jeep , jerking , YJ
