HELP!! 88 6cyl with no spark - JeepForum.com
post #1 of 5 Old 06-04-2002, 11:51 AM Thread Starter
JeepsterDave
hey guys, my 88 6 cyl won't start for me. I have the 4.2 with the carb. I replaced the coil, wires, plugs, cap&rotor, that primary coil unit under the dist cap, and even the ignition control module. The motor gets gas fine, but I am getting no spark. I don't think it has anything to do with the distributor because I can't even get spark coming from the coil wire. Everybody I've talked to at the parts stores thinks its the ICM, but I just replaced that...no luck. Help please!
JeepsterDave is offline
post #2 of 5 Old 06-04-2002, 12:20 PM
Plink
Plink's Avatar
Dave, I had the same problem with my 87 carbed 4.2. It sounds like there is a short. There is a wire that runs from the starter solenoid to the coil. The problem that I had is that the connectors on the starter sol (the small ones not the battery cable or the cable that goes to the starter). The connectors were VERY rusty and brittle. I replaced the connectors and basically checked every wire splice in the wiring harness. If your connections are fine then it might be the computer (I doubt it's the computer). From waht I've read YJs are notorious for shorts. It sucks but it's best to take your time and check all the connections and wires. Just take your time. You'll find it.
87 YJ 4.2
2" BL, 2" Shackle, 1.5" Black Diamond and Junk
31 MTRs on MOABs
Need new front and rear bumpers
HAM: KB3JQS
Plink is offline
post #3 of 5 Old 06-04-2002, 06:55 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
Is the ICM that you replaced the one that sits on the drivers side fender near the firewall? That's what gave me all kinds of problems when I had no spark and replaced everything else like you did.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #4 of 5 Old 06-04-2002, 09:18 PM Thread Starter
JeepsterDave
Yes, the ignition control module (ICM) I replaced was the one on the drivers' side fenderwell...under the coolant overflow tank.
post #5 of 5 Old 06-05-2002, 11:45 AM
avittum
have you checked the JEEP's brain box??? its located in the dash on the passanger side(pain to get to)... same thing happened to me, and after being frustrated till i was ready to push the jeep off a cliff, i took it to a shop, sure enough, they changed the box and it works fine
avittum is offline
No spark during crank but spark when key released...WTF? USMC_JeepGuy YJ Wrangler Technical Forum 16 08-03-2013 08:00 PM
6cyl xj torque con. work in a 6cyl yj ???? pepto YJ Wrangler Technical Forum 0 06-22-2009 09:12 PM
Spark plugs on a 99 6cyl Sport JfirEfightErP TJ Wrangler Technical Forum 6 05-17-2009 01:57 PM
88 jeep - 6cyl - only spark to some plugs - why?? dippa7777 YJ Wrangler Technical Forum 0 07-15-2008 08:03 AM
Help me test for fuel and spark on my 6cyl TJ.... Wheelman TJ Wrangler Technical Forum 11 11-29-2004 03:07 PM
