Help with 8.8 perch install - JeepForum.com
post #1 of 14 Old 04-12-2010, 01:17 PM Thread Starter
czjeeper
This may seen rediculous, but how do I figure out where to weld the spring perches SUA on my 8.8?
Does somebody have the dimensions for them from the center section?
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #2 of 14 Old 04-12-2010, 01:23 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Do you have your dana35 still? take measurements off that. I think spring perch width is in the FAQ above.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #3 of 14 Old 04-12-2010, 01:32 PM Thread Starter
czjeeper
So I can measure from my D35 center section to perch and be okay?
I was assuming that since the pinion was offset that I couldn't.
Thanks!
US Army combat vet
czjeeper is offline
post #4 of 14 Old 04-12-2010, 01:36 PM
jbolty
jbolty's Avatar
you need to have the proper width, proper centering and most important proper location for pinion angle.
don't be in a hurry.
start reading here
http://www.jeepforum.com/forum/f12/f...inally-636291/
jbolty is offline
post #5 of 14 Old 04-12-2010, 01:48 PM Thread Starter
czjeeper
start reading here
I know about the pinion angle setup, just wondering about the distance from the pumpkin.
I have read that link.
The best answer I get from that is moving 9/16th's out board.
Is that the same for both sides?
US Army combat vet
czjeeper is offline
post #6 of 14 Old 04-12-2010, 01:53 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Thanks!
No. you cant. I did this swap on my own. my width was fine but my pinion angle was wrong after it was welded. I spend a lot of time reading about 8.8 swaps. I used the angle finder and set it as most write-ups say it should be. it was wrong. call a buddy that has swapped axles before. takes too much time if you go it alone and are wrong, trust me.
Poke is offline
post #7 of 14 Old 04-12-2010, 01:54 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
you are trying to measure off the wrong place. measure from the backing plates in to find the right width. dont measure off the pumpkin.
Poke is offline
post #8 of 14 Old 04-12-2010, 01:55 PM
themoz
Just set the jeep on the axle as centered as you can so everything sits the way it wants to. With everything on there...tires, perches, u-bolts, etc. Then tighten the u bolts just enough to keep the pinion from flopping onto the floor under its own weight. You can then kinda tap the perches around with a mallet until its centered perfectly (its easier than it sounds trust me) Then set your pinion angle. Light tapping w/ a mallet to rotate it up or down is all it takes as long as the ubolts are just tight enough to hold things in place. Then recheck side-to-side measurements one more time and recheck pinion angle one final time if you had to make any adjustments to the perches again. Tack the perches in place then pull the axle back out and finish welding them up.
I did all this, then stopped and ordered the shaft to length, and then installed the shaft before tacking anything in place. Very easy.
themoz is offline
post #9 of 14 Old 04-12-2010, 02:05 PM
timatoe
timatoe's Avatar
The best answer I get from that is moving 9/16th's out board. Is that the same for both sides?
Yes, 9/16's out from the original 8.8 perch, each side. If you've already cut them off and ground everything smooth,,,,, I think there's a write up on Stu Olson's site with measurements.
EDIT: Here... http://www.stu-offroad.com/axle/8.8axle/8.8axle-1.htm This is for a TJ, but has the 8.8 measurements, you can compare those to the D35 if you already cut off the stock 8.8 stuff.
timatoe is offline
post #10 of 14 Old 04-12-2010, 04:33 PM
notmyj
Not hard to do this. If your spring under, get the axle sitting on top of the springs. Put the purches on the springs, then set axle on the perches. Measure from the backing plates to springs. Make this measurement the same on both sides. Put ubolts and spring plates on, and snug them up. Put jack stands und er the axle tubes and put the weight of the jeep on the axle. Use a floor jack on the pinion flange to raise the pinion to the correct angle. When its there, tack the spring perches to the axle. Remove the plates and ubolts, and weld it in.
Just be sure to use big tack welds so you don't break them when you move the axle for final welding.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #11 of 14 Old 04-12-2010, 06:36 PM
joshbaker92yj
thats just about ow i did it last weekend. believe me its not that bad. heck, i set everything up on the jeep, measured 4 times, marked the spring perches and shock tabs with a paint pen. Then i took the axle out put it in my tuck drove to dads house and we welded everything up. Went back to the shop and everything dropped in place.
92 yj, 36 sx swamper, locked d30 and locked 8.8.
on the road again.
joshbaker92yj is offline
post #12 of 14 Old 04-12-2010, 06:49 PM
DaveinHouston
EXACTLY what notmyj said. This is not something to do outside the Jeep. Set it up underneath and get all of your measurements and angles right and tack weld the perches to the tubes. Then you can either weld it out in place or take it out and weld it on stands.
- 2003 Rubicon - 4" Lift, 35" KM2s, 5.13 gears, winch
- 1968 CJ5 - Dauntless V6, T-86, Dana 18, D27 & D44
- NRA Life Member - Licensed to Carry and Do.
DaveinHouston is offline
post #13 of 14 Old 04-12-2010, 10:56 PM
RockWoRM
RockWoRM's Avatar
No need for dimensions.
Hopefully, you've not cut off the old 8.8 fac. perch's yet. If not, then there is no need to do all the extra measurements and trying to center the diff/axle.
Simply measure out 9/16" (out meaning towards the hub/wheel) from the old fac. perch and mark the spot with something that won't get erased. I used a hacksaw and scribed a line. Cut off your old perchs. Mock up axle with new perchs set on these marks. Since the 8.8 is 1.25" shorter than the turdy 5, moving each perch out 9/16" will put it spot on. Set your pinion and you're done!
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #14 of 14 Old 04-12-2010, 11:05 PM
Alabamaranger
That us what I did, plus check it from the frame to the backing plates. Did it over and over until I was happy. Than I did the pinion angle. Tacked everything and rechecked everything again.
90 YJ, 4.2 with 2150 carb 4.0 Head and headers, Nutter with TFI and MSD. 1" BL, 2.5" spring lift, 33", Goodrich KM Mud Tires. Dana 30 w Aussie, Ford 8.8 w LS. 9000lb HF Winch.
Alabamaranger is offline
leaf perch distance KC1337 YJ Wrangler Technical Forum 2 07-25-2009 07:35 PM
8.8 Spring perch Poke YJ Wrangler Technical Forum 18 03-19-2009 08:16 PM
Spring perch mcgratht TJ Wrangler Technical Forum 6 03-26-2006 04:22 PM
8.8 stock spring perch jeepin_coug YJ Wrangler Technical Forum 14 04-01-2005 12:46 PM
Perch to Perch ( not about birds ) :) biohazardbill YJ Wrangler Technical Forum 1 02-04-2004 02:36 PM
