Help with 8.8 conversion - JeepForum.com
post #1 of 4 Old 02-23-2014, 06:33 AM Thread Starter
joepug
Does anybody have or know where you can get the measurements for the placement of the spring perches on 8.8 explorer rear end would be much easier if I can weld it all up and paint without havering to mock it up and take it apart to do so and also the best angle with a 4 inch lift
joepug is offline
post #2 of 4 Old 02-23-2014, 07:21 AM
sptrmike
sptrmike's Avatar
There is info on the net, I googled it a few years ago when I was going to do the swap, drawings for perch placment and how to set your pinion angle to do exacly what you want to do,build the axle and bolt it in. Maybe Jedi I think I saved it, I have to finish my brake job, when I'm done I'll see if I can find it!
sptrmike is offline
post #3 of 4 Old 02-23-2014, 08:14 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You'll need to mock it up underneath to get the pinion angle just right.
Trust me guys, its totally worth it to do it right.
Luck Favours The Prepared
Anticanman is offline
post #4 of 4 Old 02-23-2014, 09:00 AM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by anticanman View Post
you'll need to mock it up underneath to get the pinion angle just right.
yup!!!
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
