help! 4wd problems - JeepForum.com
post #1 of 7 Old 07-09-2013, 07:14 AM Thread Starter
drewyj
help! 4wd problems
94 yj, 4.0l
ford 8.8 in rear w 4:10 gear ratio
dana 30 front with 4:10 and Aussie locked
my problem started not too long ago, everything was fine
then 1 day i put it in 4wd and went to go and heard this " CLUNK!"
noise.. i stopped and looked underneath and saw nothing visiable
now when i put it in 4wd (high or low) it pulls to the right and makes this "clunk" that is very loud.
it almost sounds as if the chain inside the t case is slipping then catching, or maybe i have a broken tooth on a gear inside the t case?
i looked in front axle and nothing looked wrong.
any idea what this could be? thanks in advance!
drewyj is offline
post #2 of 7 Old 07-09-2013, 07:38 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
If you think its internal theres only one thing to do: pull the case and take a look. Might as well have a chain upgrade standing by.
Luck Favours The Prepared
Anticanman is offline
post #3 of 7 Old 07-09-2013, 09:36 AM
gtg413i
2003 WJ
Also snap ring pliers and the transmission mount bushings. Take the whole transfer case out. It is much easier to work on. Also, you need to support the transmission with a jack.
Brian's Black Betty Build:
gtg413i is offline
post #4 of 7 Old 07-09-2013, 10:51 AM Thread Starter
drewyj
the only thing that makes me wonder is why does it pull to the right? my t case wouldnt cause it to pull... would it?
drewyj is offline
post #5 of 7 Old 07-09-2013, 11:43 AM
NHfireLJ
NHfireLJ's Avatar
locker will...
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #6 of 7 Old 07-09-2013, 11:45 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Check for broken shafts and ujoints.
post #7 of 7 Old 07-09-2013, 03:50 PM Thread Starter
drewyj
u joints and shafts are good.... im starting to think its my locker... any way to test it?
drewyj is offline
