Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Help
XJ guys, clock your transfer case!D.i.y. Ford 8.8 tj,xj,yjTrek Armor Seat Covers now at JeepHut
Unread 10-12-2007, 05:11 AM   #1
Navy_Jeep_Dude
1987 YJ Wrangler
Help
I need some help over here.
I have an 87 YJ with a manual tranny in it. There were problems starting with the carb and I did a small adjustment on it because when I started to slow down it would stall out. Now it seems to have got worse, now when I put the clutch into first the jeep wants to keep on going forward and I am having a very hard time putting it in gear which started last night. It is getting hard to even put it in gear.
Any help would be appreciated.
Ron
Navy_Jeep_Dude is offline   Reply With Quote
Unread 10-12-2007, 06:42 AM   #2
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
For the carb problems you need to check out these links:
http://home.sprynet.com/~dale02/list.htm (Carb issues)
http://www.4x4wire.com/jeep/tech/ele...jn-ignition99/ (Nutter Bypass)
http://www.jeeptech.com/engine/carter.html (Venturi tube cleaning)
http://jeepcarterbbdcarb.com/kit.html (replacement Venturi tube, better than stock)
As far as the tranny goes, Welcome to the world of the POS Puegot BA 10/5 5speed. My first thoughts are, check/change your tranny fluid. Second, how is your clutch fluid?
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
