Help!!!...4.2 bogging down bad on acceleration - JeepForum.com
post #1 of 3 Old 04-25-2013, 11:33 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
My 4.2 boggs down real bad at half throttle. Idles fine and revs fine until I start to move then boooooggggggg. Crazy thing is this only happens when my 600 pound girlfriend is hanging on to the rear tow hook when I leave for the bar.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #2 of 3 Old 04-26-2013, 12:38 AM
04WJny
1987 YJ Wrangler
do you have the stock carter carb? there know to be pretty terrible, more so with 600 lb girlfriends hanging on tow hooks
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #3 of 3 Old 04-26-2013, 02:48 AM
Squirrel442
You need to get the "no fat chicks sticker" or a V8.
I would check your fuel filter, air cleaner. If they are clogged it will cause fat chicks to hang on your bumper.
I have herd bad coil and worn plugs can also cause it too.
Last, check to make sure you did not run over a BBQ sauce packet from McDonald's. If it squirted on the bumper they can smell that from a mile away.
Squirrel442 is offline
