Help with 4.0 swap - Page 4 - JeepForum.com
post #46 of 51 Old 09-20-2012, 07:37 PM
mrmark
Originally Posted by Que89YJ
Yes the ecu will work and he has multiple harnesses. Both of you get in touch with him and tell him I sent you.
Well then I should be in like flynn once i get the harness in the mail... as long as there are no other issues. Crossing my fingers.... oh I have 2 harnesses for sale too ... and a whole bunch of other stuff clogging my shed
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #47 of 51 Old 11-05-2012, 09:08 AM
Que89YJ
I have been out of the loop trying to get my car running again. Did you get it figured out?
Que89YJ is online now
post #48 of 51 Old 11-05-2012, 10:48 AM
SSRx7
Hey guys, I know this thread is a few weeks old, but depending on where you are at in your harness struggles, I got a complete harness (for the whole jeep) on ebay for $250. I had to do that as my yj is an 88. Since you both have 91 or newer YJ's, you should be able to just use the 4.0 engine harness. If I remember correctly, it is a plug and play to the 2.5 bulkhead connector, but you want to check it just to be sure. I got my harness at http://stores.ebay.com/alljeepparts401
This should make you wiring a whole lot easier and you wont have a rat's nest.
By the way, the reason that I had to get the whole harness is because I went from a carbed 4.2 to the 4.0. I had to redo my gauges to the newer style, basically the entire jeep. You guys are ahead of the game because you have the newer jeeps. Hope this helps.
SSRx7 is offline
post #49 of 51 Old 11-05-2012, 11:00 AM
SSRx7
Update: I just checked and he doesn't currently have a 4.0 engine harness listed, but check back in a couple of days and he should have one. You can also call them and see when he will have one. It made life so much easier for me when I did mine. I started by doing the "5 to Fire" process I found on line and ended up with a worse rats nest than you guys have.
Again, hope this helps.
SSRx7 is offline
post #50 of 51 Old 11-05-2012, 01:08 PM
seraph_rapture
Also curious if things worked out for Mrmark. My jeep is currently running sans speedo, but would love to just put in a stock 4.0 harness if it's really that simple.
From 2.5/AX5, 30" Geolander, 2" BL
TO 4.0/AW4, 2.5 OME SOA, 5/8" boomerangs, 8.8 Aussie locked, D30 CAD eliminated, 35" Radial Rover, JCR 4x4 front and rear bumpers, ENGO 9000, Volvo e-fan, TJ rock rails, etc etc.
seraph_rapture is offline
post #51 of 51 Old 11-05-2012, 02:38 PM
remmons
I have been out of the loop as well. I like hearing success stories on these 4.0L swaps as that mine was a success as well.
Robert.
remmons is offline
