Help!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Help!!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Solution to Radius Arm Bind - Meet Lock-N-LoadFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 10-19-2014, 01:53 AM   #1
Corbeau03
Help!!
Hello,
A few days before I had "check engine" and power indicator said my alternator was not running anymore... Fuse was dead, put a new fuse but it crashed instantly.
I finally changed alternator, everything was ok during 150 miles the problem appears again :-(
Check engine and low power
Is anybody already got same thing??
Thank you very much
Corbeau03 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:20 AM   #2
Que89YJ
You should have 2 alternator fuses. Replace both. Check your wire that goes from the alternator to the PDC.
Que89YJ is offline   Reply With Quote Quick reply to this message
