Help! - JeepForum.com
post #1 of 3 Old 05-24-2013, 08:24 PM Thread Starter
daddyyj
Help!
I have a 1995 yj 4.0 automatic transmission I went in the water ok. had my transmission rebuilt done now when I drive for about 10 min the engine light comes on then it won't start I put a new starter on and it started once now when I turn the key nothing at all happens all the lights and everything come on could it be something with the rebuilt transmission? It has never done this ever I even drove around for a month after the water issue. I have 1500.00 into this I'm getting frustrated please help!
daddyyj is offline
post #2 of 3 Old 05-25-2013, 03:45 AM
Jeepsr4me
neutral safety switch could be the no start issue. the engine light, you need to have the codes ran.
Jeepsr4me is online now
post #3 of 3 Old 05-25-2013, 09:08 AM
XJ93
What Jeepers4me said. Your check engine light will not come on for a transmission issue on an OBD1 vehicle. That check engine light is pretty much for emissions issues. May have water damage in your cat, and I would imagine that you would have some residual damage from water to the neutral safety starter switch. Yes, even a month later as now that water has had time to properly corrode connections inside the switch.
XJ93 is offline
