Hello Fellas..... Need a little help!!!! - JeepForum.com
post #1 of 7 Old 04-24-2001, 04:53 AM Thread Starter
BigWillis91YJ
This is my first time writing but I get lots of greta ideas from the board. Well here's my predicament. Have a 91 YJ (if you couldn't tell from my username) with the 4.0 and I am getting blowby. In other words I am getting engine oil in my k&n filter and it kinda bothers me. I have a small amount of oil deposit on my exhaust tip as well... but no smoke. No considerable loss of oil in the crankcase but still about a cup of oil every coupla weeks in the air filter housing. Now comes the wierd part. The compression is perfect and she runs like a charm. No hesitation, no nothing, if you ask my baby she'll tell you for all she knows it is still 1991 and she only has 1900 miles. But in reality it is 2001 and she's ammassed 90000 miles. Any help would be appreciated. Oh yeah, I talked to a chysler tech and he mentioned something about a quart of transmission fluid in the crankcase with an oilchange will help to remove sediment from the valve cover and cure any plugs, never heard this before and am a little skeptical. Well thanks in advance for the help.... Spring fever is in full effect and I am ready to get rollin!!!!!
BigWillis91YJ is offline
post #2 of 7 Old 04-24-2001, 01:27 PM
Tonka
2015 JK Wrangler
1. Replace your vaccuumlines that run to the valve cover.
2. Pull the valve cover, remove the breather tubes, clean everything, and re-install.
This should help,it fixed mine completely.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #3 of 7 Old 04-27-2001, 05:02 PM
Tonka
2015 JK Wrangler
any luck?
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #4 of 7 Old 04-27-2001, 06:19 PM Thread Starter
BigWillis91YJ
Waitin for the weekend... I'll get back to you. Thanks again Bud
post #5 of 7 Old 04-30-2001, 01:59 PM
jeromy
about the transmission fluid.IT WORKS
It really cleans the dirt out.
Back in the day they used kerosine,but tranny fluid is way better.That's all a lot of the engine cleaners are,but way overpriced
jeromy is offline
post #6 of 7 Old 05-07-2001, 09:58 PM
ChevyYJ
Maybe you need a new head gasket? Probably not since you have good compression. Id try a lot of other things before taking 1 full day to change a head gasket!
I just thought I would bring up Head Gasket so you have another thing to add to your list heh. Later!
ChevyYJ is offline
post #7 of 7 Old 05-22-2001, 04:14 PM
yjjay
about that trans fluid in the oil you just add 1 quart and change it in 3000 again or what? e-mail me thanks
95 yj rio grande
2-inch lift
30-inch sport kings
4-banger
yjjay is offline
Tire question fellas, need some info ImportInvasion TJ Wrangler Technical Forum 5 01-02-2010 12:00 PM
95 yj master cyl line fittings?? help fellas ghost183 YJ Wrangler Technical Forum 3 05-15-2009 08:21 PM
I'm pretty excited fellas Ares YJ Wrangler Technical Forum 3 07-28-2007 01:08 AM
Need some help here fellas! numnuts TJ Wrangler Technical Forum 3 10-11-2005 06:43 PM
Hows this look fellas? SixInline TJ Wrangler Technical Forum 17 09-20-2004 10:49 PM
