Helllpp 92 won't start - Page 2 - JeepForum.com
post #16 of 22 Old 04-16-2013, 08:44 AM
Que89YJ
yes. mts is pretty good. Max is a good judge and helps alot on the forum. He recommends them but the sending unit should work as long as it is for a 91/95 yj.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #17 of 22 Old 04-16-2013, 09:03 AM Thread Starter
SRH92YJ
cool ya mines a 92. looks like i can get it on ebay for $160 delivered get it by monday or pay 166 through jc whitney and get it 2 day delivery
SRH92YJ is offline
post #18 of 22 Old 04-22-2013, 11:32 AM Thread Starter
SRH92YJ
Well got the new sending unit and like the old one it doesn't want to fit back in. Did some searching and I'm guessing my tank is warped. So after all the trouble of cutting an access hole an everything I now have to drop the tank again and disconnect the straps and hope I can get it to fit. Don't have the extra 350 for a new tank right now. This sucks
SRH92YJ is offline
post #19 of 22 Old 04-22-2013, 11:59 AM
Que89YJ
It is might be the return line bottoming out. You might be able to get it in by just cutting back the return line. Are you sure you are not bottoming out on the white tray in the bottom?
Que89YJ is offline
post #20 of 22 Old 04-25-2013, 09:58 AM Thread Starter
SRH92YJ
Pretty possitive it's the bottom. Even if I trimmed the return line the pump doesn't sit much higher. And the sending unit is sitting like an inch too high
SRH92YJ is offline
post #21 of 22 Old 04-25-2013, 11:34 AM Thread Starter
SRH92YJ
Well I pulled the tank out of the straps and checked the bottom of the tank. Sure enough I had a small dent in the skid plate pushing up against the tank put a little dent in it and buckle in the whole bottom. Got the tank plugged up now sitting in the sun trying to pop it out to normal
SRH92YJ is offline
post #22 of 22 Old 04-25-2013, 01:46 PM
Que89YJ
Glad to hear it.
Fault codes:
No Start:
Que89YJ is offline
