To Heli or not to Heli(coil) - Page 2 - JeepForum.com
post #16 of 31 Old 07-03-2013, 07:30 AM
TSEJEEPERS
What about using something like this?
I am sure this is not the right size but they do have different ones. http://www.napaonline.com/Catalog/Ca...139_0407316665
Here is where they are on Napa's website
http://www.napaonline.com/Catalog/Re...875&Ne=1000000
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #17 of 31 Old 07-03-2013, 09:39 AM Thread Starter
zchris87v
1987 YJ Wrangler
Originally Posted by JeeperDon View Post
Why temp fix it when the helicoil is a permanent fix! What are you afraid of with a helicoil?
The $50 I have to spend on it when a new caliper is $70.
zchris87v is offline
post #18 of 31 Old 07-03-2013, 09:53 AM
jason280
Chris,
Depending on how patient you are, I'll have an entire caliper assembly available once I pull my front Dana 30. I'm swapping out a 3.07 geared D30 with one in either 3.73 or 4.10, so I'll have an extra set. I'm about an hour south of you, so let me know.
jason280 is offline
post #19 of 31 Old 07-03-2013, 11:15 AM
TSEJEEPERS
Am I missing something here?
From what I understood the threads on the knuckle, that the caliper bolts screw into are stripped.
A Caliper will do you no good.
post #20 of 31 Old 07-03-2013, 01:42 PM
piotrsko
Military specifications call for helicoils on stressed aluminum parts PRIOR to initial assembly. If it good enough for the gummermant. ......
piotrsko is offline
post #21 of 31 Old 07-06-2013, 09:17 PM
mudsweatNgearz
1987 YJ Wrangler
Originally Posted by bigbossd1030 View Post
I have had to tap holes in welded cast (mud flap hanger bracket on back of winch tractor) many times before. Sure I go through a drill bit each time from all the sharpening and I have to use a retarded amount of rapid tap. And do literally 1/16" turn then back each time so I don't bi*ch my tap. But it can be done. I have done it. I wasn't the one who came up with the idea, I simply stated some of the work involved to deter away from it, then I suggested an alternative route. Don't try and give me a teaching lesson here, it would be greatly appreciated. Sorry if I sounded like a d bag, but if I wanted to learn someone's 2 cents I would have asked for it.
Sent from my iPhone, probably because I am bored at work.
Your IQ is showing...barely
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #22 of 31 Old 07-06-2013, 09:27 PM
bigbossd1030
That's your opinion and you are entitled to it.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #23 of 31 Old 07-06-2013, 10:03 PM
deathtrap
All of the factory service manuals specify them too. If done properly they are a solid repair.
deathtrap is offline
post #24 of 31 Old 07-06-2013, 10:06 PM
JohndKc
1987 YJ Wrangler
Heli-coil kits are about 20 dollars. I am not sure where you got 50. I can't remember what size it is, but i would say its 5/16. You get a ridiculous amount of inserts with these small kits too. Consider it an investment for future knuckle holes stripping out.
EDIT: If I was in your shoes Chris, I would stop looking for the perfect solution to this minor problem and fix it with a tried and proven method.
33rd BCT
Alpha 2/122 FA
68W
JohndKc is offline
post #25 of 31 Old 07-06-2013, 10:34 PM
deathtrap
In my mind the only two choices are heli-coil or replace the knuckle. your call.
post #26 of 31 Old 07-06-2013, 10:53 PM
Norcal_chris
Norcal_chris's Avatar
replacement knuckle is just going to strip again. Its easier to just helicoil it and never worry about it agian. While your at it drill and helicoil the other 3 holes so you do not have to do it later.
FWIW my buddy replaced the drivers shaft in his xj. Forgot the bottom caliper bolt. Drove 1hr up to go wheeling. Wheeled for a few hours then drove back home. Then he Drove it to work for 4 days. he came to my house after work were we noticed the bolt was gone.
generally speaking a heli-coil is stronger than the material it goes in to. Ive known a few that have used them on head bolts.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #27 of 31 Old 07-07-2013, 04:48 AM
mudsweatNgearz
1987 YJ Wrangler
A helicoil will make the threads stronger.
post #28 of 31 Old 07-15-2013, 07:14 AM
TSEJEEPERS
I hope this issue has been resolved by now.
Just learned of a kit to fix the stripped out hole.
A little exspensive but it does provide enough hardware to do two holes.
http://shop.blackmagicbrakes.com/Knu...ir-Kit_c39.htm
post #29 of 31 Old 07-15-2013, 07:41 AM
Siva283
Those are basically the same thing heli coils are.
Sent from my SPH-L300 using JeepForum
Ask me how I know...
Siva283 is offline
post #30 of 31 Old 07-15-2013, 08:00 AM
captainauti
if you want a solid repair, look into www.timesert.com . much better than a helicoil. not cheap, but very solid. just putting it out there.
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
