Hei or Team Rush ? Which is best ? - JeepForum.com
post #1 of 12 Old 10-17-2008, 09:05 PM Thread Starter
mtidwell
I am going to do one of the ignition mods to the yj.
I know it is personal preferance on some of it , but what is your experience on which one makes the most difference. Seems to me like just stabbing a dist. in and go is easier than the team rush parts gathering and installation. What do you guys think ?
The Fireman
mtidwell is offline
post #2 of 12 Old 10-17-2008, 09:11 PM
Brandon_YJ
1987 YJ Wrangler
Team Rush is actually quicker/easier... you don't just "stab a dizzy" in there.
I did the Team Rush, and couldn't be happier.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #3 of 12 Old 10-17-2008, 10:11 PM
Flynraider
I did the teamrush mod as well and am very happy with it. I believe that with HEI you have to change out your dizzy gear or spend a pretty good chunk of change on a kit if you want one that "just stabs in"
Either way I would have to agree that the teamrush mod is better from an ease of installation standpoint.
I thought I made a mistake once, but it turned out that I was mistaken.
Flynraider is offline
post #4 of 12 Old 10-17-2008, 10:15 PM
timatoe
timatoe's Avatar
I think it's gonna be totally preference, as I doubt many (if any) guys have ran both on the same rig. I run the HEI and have had zero issues and am very happy with the improvement.
timatoe is offline
post #5 of 12 Old 10-17-2008, 10:32 PM
Brandon_YJ
1987 YJ Wrangler
I ran an HEI on my 442 back in the day, and had one in my Eagle Wagon. Was a drop in for the 442 (obviously) but had to grind the gear to get it to work in the 4.2 in the Eagle.
I was happy with it... no complaints.
in a (text only)
post #6 of 12 Old 10-17-2008, 10:36 PM
Burnerman
Burnerman's Avatar
I run an HEI with 0 trouble. To me having everything in one spot and easily available is cleaner and easier.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #7 of 12 Old 10-17-2008, 10:43 PM
pat8942
pat8942's Avatar
I don't have either one obviously.
IMO HEI has a slight advantage because you upgrade the complete distributor and you eliminate the need for the Duraspark ignition module.
As far as changing the distributor drive gear goes,you can change the gear in less time than it takes to change a tail light bulb.
But I suppose it's all in what you prefer.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #8 of 12 Old 10-17-2008, 10:54 PM
dbikers
team rush (or the the "juice-box") is typically cheaper.
crt performance sells a complete kit for about $100...nice because it uses your distributor and dist gear which was designed for our jeeps
i have a crt performance hei...so far i like it, BUT i have heard that the cheaper hei clones (crt [i]may[/] be included as one of the "cheaper" clones) have issues with the distrib gear being too hard and trashing the cam gear.
i've heard the best hei clone is the DUI system (but expensive) and that you should not buy the $99 one out of some of the jeep catalogs as they are way cheap (built in china).
if i had it to do over again i'd do a team rush (or the juice-box)...a little cheaper and perhaps safer..
A GREAT place to research is in the CJ section of JF...alot of info to mull over
just my .02....
STUPID HURTS.......OUCH!@#$
dbikers is offline
post #9 of 12 Old 10-17-2008, 11:20 PM
Burnerman
Burnerman's Avatar
I have 5000 mi on my CRT with no issues. My Stock dist had worn bushings and alot of play. If the gear is a concern get a DUI, Davis Unified Ignition. They are big $$ but I've never heard anyone complain about them.
96 ZJ.
post #10 of 12 Old 10-17-2008, 11:29 PM
kenny kustom
I run a Mallory HEI on my 360. Never knew the " before " though.
1989 yj. AMC 360, Cj front clip and custom interior/dash. Herculiner inside and out, Dana 60's, 5.38's, ARB's. 40" iroks.
2008 JK Rubicon Unlimited.
kenny kustom is offline
post #11 of 12 Old 10-17-2008, 11:52 PM Thread Starter
mtidwell
I have ran a dui in a race car before ,, no problems at all , but that was a 350. so not really the same. Huge improvement though when it was added.
What is the deal with the gear, the ones that I am looking at on ebay come with a gear on them , all of them ,, CRT, cheaper ones, and the DUI ?
What am I missing on the gear ? I understand that some may be too hard ?
So what are people buying the hei dizzy that comes with a gear on it, puling that gear off,then changing the gear and putting on the gear from the original dizzy that is pulled out ?
The Fireman
mtidwell is offline
post #12 of 12 Old 10-18-2008, 12:38 AM
timatoe
timatoe's Avatar
The only thing I've ever seen (and encountered) is when you build your own using a distributor from a GM truck or van, you have to change the gear. The ones you buy for the Jeep are ready to go.
timatoe is offline
team rush vs HEI bigorangeyj YJ Wrangler Technical Forum 6 12-19-2009 02:00 PM
Team Rush and gas mileage..? fishmanwill YJ Wrangler Technical Forum 4 12-17-2009 08:48 PM
HEI or Team Rush?? bjbrowder YJ Wrangler Technical Forum 17 11-19-2009 11:39 AM
Team Rush Up Grade yjmikea YJ Wrangler Technical Forum 2 01-07-2009 08:38 PM
team rush NJscott YJ Wrangler Technical Forum 2 06-10-2008 08:16 AM
