HEI or Team Rush?? - JeepForum.com
post #1 of 18 Old 11-18-2009, 06:38 AM Thread Starter
bjbrowder
HEI or Team Rush??
Which mod is better? Not considering the cost, they are about the same, (ebay HEI dist $75), team rush mod $65-100. What do ya'll think? I have done the Team rush mod, nutter, weber, some wiring, and still have a skip. Thinking strongly on the HEI dist.
bjbrowder is offline
post #2 of 18 Old 11-18-2009, 07:48 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
I have a Weber and Team Rush, this all worked great but when I added a MSD to the package things really improved. I do not feel comfortable with the HEI mod because some cheap china HEI's can be found online with hardened steel gears, which eat up your camshaft and ruin the engine... what you need to improve now is your ignition module with a Summit or MSD model... just my $0.02
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #3 of 18 Old 11-18-2009, 07:55 AM
USMC_JeepGuy
I did the HEI but I pulled one out of an old Chevy @ the junkyard, cost $30 + a new cap/coil for $15, swapped out a 304 gear my buddy had and haven't looked back. No experience with the Team Rush so I can't compare but I do love my HEI, besides I love the strange looks those not in the know give me when they see a GM ignitino on a Jeep motor...
USMC_JeepGuy is offline
post #4 of 18 Old 11-18-2009, 08:04 AM
spshultz
1987 YJ Wrangler
What do you mean by skip? By skip do you mean at 2000 RPMs (or what ever RPM) there's an intermittent miss in the firing? Or that when you go to take off from a stop the engine hesitates for a second? Sorry to ask. Everyone has different description for a skip, miss, bog, etc.
spshultz is offline
post #5 of 18 Old 11-18-2009, 01:26 PM Thread Starter
bjbrowder
It skips at idle, and threw the rpm range, especially when the engine is cold. The skip isn't constant, or in a pattern. Its just here and there (BaaaaaaaBaBaaaaaaaaBaBaaaaBaBaaaaBaBaa)
post #6 of 18 Old 11-18-2009, 01:41 PM
Fhajad
I have that sorta sound with my 4.0L. I have no idea what the cause is.
Fhajad is offline
post #7 of 18 Old 11-18-2009, 01:42 PM
Sprungover
team rush is easy to do and will perform as well, if not better than the HEI.
Sprungover is offline
post #8 of 18 Old 11-18-2009, 01:54 PM
jbolty
jbolty's Avatar
Sheep?
I have an HEI from CRT Performance and have been very happy with it. That made more sense after pricing out the junkyard version with new cap, rotor, coil and wires. Plus the gear.
jbolty is offline
post #9 of 18 Old 11-18-2009, 03:23 PM
timatoe
timatoe's Avatar
I did mine from a Junkyard, shoulda just gone with the CRT HEI, just because cost of junkyard parts here is so pricey. The HEI units themselves are basically the same, but the cheap ones on eBay have had issues with the cam drive gear on the HEI chewing up the actual cam gear. If you go HEI, I'd suggest the CRT unit or grind down your stock gear to the right length and swap it out if another HEI unit.
I have no experience with the TFI (team rush) but I believe it still uses the duraspark ignition box, which is a common failure item.
timatoe is offline
post #10 of 18 Old 11-18-2009, 03:31 PM
ImpactFabWorks
I did my team rush and it was a amazing improvement. i got the e-coil for $10 and all the other parts for about $50 new at auto zone. i don't have any experience with HEI. but i like my team rush
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #11 of 18 Old 11-18-2009, 03:36 PM
Douglas S.
Junkyard HEI here with an AMC 360 gear, no problems at all
1991 Land Cruiser HDJ81
Douglas S. is offline
post #12 of 18 Old 11-18-2009, 04:13 PM
timatoe
timatoe's Avatar
Where'd you find that gear?
timatoe is offline
post #13 of 18 Old 11-18-2009, 04:19 PM
jbolty
jbolty's Avatar
Telico 4x4 had them for the cheapest price, when I was looking. Maybe $18.
Was still not worth it to me after adding up the cost of a JY distro along with the other parts. Plus the distro you are looking for is pretty old, mid 80's, and might be worn out
jbolty is offline
post #14 of 18 Old 11-18-2009, 04:24 PM
Reverb
+1 (from ebay)
Reverb is offline
post #15 of 18 Old 11-19-2009, 06:01 AM Thread Starter
bjbrowder
I have the team rush on my now, but I wish I wouldva went with an HEI dist.
Think about it, I spent about $100 on the team rush mod, and I still have a 21 year old distributor with 172k miles on it, it is probly wore out, shaft play, weak springs, and not worth keeping. If anyone would like to buy my 1 month old Team Rush components, I will gladly sell them for a good deal. All the parts are the ones in the write up excep the coil. I bought a MSD Blaster 3 coil.
team rush vs HEI bigorangeyj YJ Wrangler Technical Forum 6 12-19-2009 01:00 PM
Team Rush and gas mileage..? fishmanwill YJ Wrangler Technical Forum 4 12-17-2009 07:48 PM
Team Rush Up Grade yjmikea YJ Wrangler Technical Forum 2 01-07-2009 07:38 PM
Hei or Team Rush ? Which is best ? mtidwell YJ Wrangler Technical Forum 11 10-17-2008 11:38 PM
team rush NJscott YJ Wrangler Technical Forum 2 06-10-2008 07:16 AM
