Hei swap - JeepForum.com
post #1 of 3 Old 06-13-2013, 07:02 PM Thread Starter
Jambonez
Hei swap
Hi guys
Ive got a 90 4.2l and am doing the HEI conversion. I got a dizzy from a 79 blazer and the oil pump drive has the floppy end on it. Is this what I want or do i need a solid shaft? Also will a 72 AMC V8 gear fit.
Thanks in advance
Jambonez is offline
post #2 of 3 Old 06-13-2013, 08:21 PM
bgredjeep
1987 YJ Wrangler
If the distributor is from a 6cyl it should work. For the gear, pretty sure the v8 gear is not the same. You should be able to use the one from your original dist, but you might have to grind it down a little to make it fit. My OE gear was too tall on my 87. I started grinding it down, but there happened to be another older 4.2 at my buddy's shop where I was doing the swap (78 I think) and the gear from that dist fit perfect.
bgredjeep is offline
post #3 of 3 Old 06-14-2013, 12:00 AM Thread Starter
Jambonez
My old gear is to loose of a fit on the shaft I have to find one with a smaller ID.
Jambonez is offline
