Heavy duty trailer hitch - JeepForum.com
post #1 of 6 Old 02-25-2002, 11:07 AM Thread Starter
NewVAjeeper
I just bought a 92 YJ and I am having trouble finding a heavy duty trailer hitch. I want to mount a dirt bike carrier to the hitch reciever but need a minimum 500 pound tongue weight. All I can find are class one hitches. I need a minimum of a class three if not a class four. Does anyone know where I can find one? Thanks for your help
NewVAjeeper is offline
post #2 of 6 Old 02-25-2002, 01:26 PM
SFAJeeper
I dont know where you have looked, but you might want to check with Drawtite company. On there website, www.drawtite.com , there is an email address and phone number for types of applications and help with hitch questions.
axe 'em jacks
92 YJ 33" MTR's 2.5" lift
shackles and more junk.
Somebody buy me a lift!
SFAJeeper is offline
post #3 of 6 Old 03-05-2002, 07:43 PM
JK TN
Got mine at Quadratec. It's a 3500 lb tow rating w/350 lb tongue wgt rating, but I've pulled a 16" trailer with 450-500 lb tongue wgt with no problem. It's a 2" receiver. This should work just fine for you. Costs about a hundred dollars.
Hope this helps...good luck.
Jerry Kirkpatrick
95 YJ Sahara 4.0L I-6/5-speed, Rancho RS9000 shocks
JK TN is offline
post #4 of 6 Old 03-05-2002, 07:46 PM
evilpsych
evilpsych's Avatar
*sigh* he really needs the class 4 rating.. i dont think you're going to find one because i believe that 500 lbs is enough to make the front end pop off the ground.. if you really want to carry a dirt bike w/ your jeep, your best bet will be to get a flatbed trailer..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #5 of 6 Old 03-05-2002, 07:53 PM
ebhub
I would definately go with a trailer.I towed a motorcycle plus gear when I moved from Florida to Boston.Properly set up I couldn't tell it was back there except when stopping.
National Tool and others make 4x8 folding trailers cheap.I fold it out of the way when not in use and use to haul everything.Lets faceit NOTHING fits in a Jeep.4wd.com has them for about 100 bucks
ebhub is offline
post #6 of 6 Old 03-06-2002, 05:12 AM Thread Starter
NewVAjeeper
Thanks for the advice. I think the folding trailer is the way to go.
Heavy Duty Vs. Light Duty Lift (OME) jmo TJ Wrangler Technical Forum 19 03-08-2011 10:40 PM
OME HK (Heavy Duty) Suspension Kit- Launch Time Without Heavy Bumper? hikerpaddler TJ Wrangler Technical Forum 8 03-11-2009 11:50 AM
light duty vs. heavy duty lift jgillespie YJ Wrangler Technical Forum 5 06-05-2008 08:33 AM
heavy duty oil pan?? rem TJ Wrangler Technical Forum 2 10-29-2005 07:13 PM
Heavy duty tie rod Glass TJ Wrangler Technical Forum 13 10-21-2005 02:00 PM
