Heavy Duty steering system for a lifted YJ - Page 2 - JeepForum.com
post #16 of 24 Old 07-30-2013, 03:26 PM
jsd1991yj
I have been running the Rusty's kit for a couple of months now. I am happy with it. Deffinitely a lot more stout than stock.
jsd1991yj is offline
post #17 of 24 Old 07-30-2013, 06:09 PM
jason m
Nothing but the facts
jason m's Avatar
Originally Posted by rambo3489 View Post
I disagree. Maybe the joint itself. But there's a bolt through it to worry about. Which is grounds for play. Mines been fine no complaints. But to me a TRE would have less play. Until it's worn..
Sent from my phone because I'm doing something "more important"
Just put the joints in double sheer, This is a friends 44 front.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #18 of 24 Old 07-31-2013, 03:38 AM
zte87
GIVE IT THE ONION
zte87's Avatar
Another vote for the ruff stuff gm 1tone setup here I love mine!
zte87 is offline
post #19 of 24 Old 07-31-2013, 02:49 PM
AmmitOsiris
I vote for rustys, that's what I got and it's good for me, better than stock handling also
AmmitOsiris is offline
post #20 of 24 Old 07-31-2013, 03:24 PM
taylor797
I just put the ruffstuff 7/8" heim steering kit on mine and it seems to be excellent quality
taylor797 is offline
post #21 of 24 Old 07-31-2013, 03:24 PM
fratis
fratis's Avatar
Originally Posted by ArticRubi View Post
What would make you question it? Definitely less slop in a heim joint vs a TRE.
If you are comparing a damaged worn stock unit with an FK rod end then yes you might experience that. Compare an EMF TRE with one of the many crappy rod end manufacturers and you will experience the opposite. Until i realized only the finest quality rod ends were worth buying i had many sloppy rod ends.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #22 of 24 Old 08-16-2013, 07:18 PM Thread Starter
Duke78
Thanks guys for info, I think I'm going to go for the Ruff Stuff Y-link. But I'm thinking of doing the Durango steering box upgrade first since I can get that done right away. Hopefully it will help with driving at highway speeds shakiness.
Any guys done that? I've heard good things about it.
Cheers
Duke78 is offline
post #23 of 24 Old 08-16-2013, 10:32 PM
Day215
I'll second your choice of going with the RuffStuff set up. I moved the tierod over the knuckle and swapped to an astro can pitman arm for clearance reasons. I bought a poly spacer from JCR, it's still a Y link but my dead spot is minimal compared to my trashed stock setup. It cost me a little more than replacing it with the stock stuff, my TREs were shot so it was a necessary upgrade.
Day215 is offline
post #24 of 24 Old 08-17-2013, 06:51 AM
calvynandhobbs
calvynandhobbs's Avatar
I'm putting a Waggy D44 with flat tops in my YJ and one thing I've found is that if your state has inspections heim joints may not work since they are not DOT approved in most states.
94 YJ - work in progress
calvynandhobbs is offline
