Heavy Duty steering system for a lifted YJ - JeepForum.com
post #1 of 24 Old 07-29-2013, 05:37 AM Thread Starter
Duke78
I have a 4.5" RE lift with 33" tires and it seems every time I hit a small bump my alignment goes out. I've tried looking up various options to replace the OE stuff. Everyone says Currie is the best but I don't think they make them for YJs and I sent them an email to see if they do. Rugged Ridge has a kit but I don't hear good things about it. I would like a recommendation on what would be the best for mostly highway driving and weekend off-roading.
Cheers
Duke78 is offline
post #2 of 24 Old 07-29-2013, 08:35 AM
dillonjm
2013 WK
I ran Rusty's setup on my old YJ and was pretty happy with it. I liked how it was setup with ends I could get at any local parts chain, not proprietary ends you had to order direct from them.
Its not one ton steering, but that's not really necessary on a YJ.
Sidebar, if Currie had a setup for a YJ I would have run that, however. I ran their steering arms on my TJ years ago and it was top notch.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 24 Old 07-29-2013, 09:27 AM
jsipe007
ruffstuff has a DIY heavy duty steering kit that I have heard really good reviews about. Not sure if the heims/bushings are included though.
jsipe007 is offline
post #4 of 24 Old 07-29-2013, 10:08 AM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
I just received Ballistic Fab's 3/4" heim DIY setup. Haven't installed yet but it's a pretty simple process. If you can't weld you could still do all of the setup for it and once your tubing is the right length bring it to a welder, probably cost you less than $25 to have it done.
It ditches the Tie Rod Ends for heim joints and also does away with that ****ty Y-link design. Ballistic uses 1.25x.250 DOM for the links.
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #5 of 24 Old 07-29-2013, 11:51 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I have the same springs up front and run the rugged ridge kit. My jeep also sees mostly highway.
What does your drag link look like?
Luck Favours The Prepared
Anticanman is offline
post #6 of 24 Old 07-29-2013, 12:35 PM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Just to add a link to the Ballistic Fab kit I referenced above:
https://www.ballisticfabrication.com...rs_p_1335.html
There would be zero downfall to running this on the street. It will be more responsive than a TRE setup and much sturdier on the trail. The kit includes everything you need except some 3/4" nuts and bolts to attach the links to the knuckles and pitman arm. Pretty cheap at $240 plus shipping.
Also, noticed its actually 1.5x.250" DOM not 1.25" like I thought.
post #7 of 24 Old 07-29-2013, 01:12 PM
Lemoore-on
I just put Rusty's kit in mine. I seem to have a dead spot now. I need to double check my alignment.
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #8 of 24 Old 07-29-2013, 06:00 PM
crackedcornish
http://www.jpmagazine.com/shop4parts..._buyers_guide/
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #9 of 24 Old 07-29-2013, 06:56 PM
1946Flattie
I'm also running the Rugged Ridge steering. It's been holding up find for me for two years now. Only drawback is the tie rod will contact the stock diff cover at full lock due to the larger OD tubing, so I'm going to say it would really have issues with a larger aftermarket cover. Other than that I'm happy with it.
1946Flattie is offline
post #10 of 24 Old 07-29-2013, 07:44 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
My RR barely clears the stock cover with factory steering stops
And I opted for a different diff guard
post #11 of 24 Old 07-29-2013, 10:15 PM
tydp
I run..
the JCR over the knuckle one ton setup....I like it....I went with over the knuckle to help with drag link angle....I don't run a dropped pitman arm
tydp is offline
post #12 of 24 Old 07-29-2013, 10:20 PM
rambo3489
Build your own linkage. If your fab skills are up to par. You can see pictures of what I created in my build thread. No details. But I can give your pointers if you want. It's really easy and REAL strong. The hardest part is drilling your knuckles. (mentally challenging) something about drilling perfectly good tapers...
But if your not up to going that extreme I say get one of the recommended aftermarket linkages recommended here and call it good.
Sent from my phone because I'm doing something "more important"
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #13 of 24 Old 07-30-2013, 01:29 AM
fratis
fratis's Avatar
what would make you state this?
-insert meaningless out-of-place political diatribe-
fratis is offline
post #14 of 24 Old 07-30-2013, 07:40 AM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
What would make you question it? Definitely less slop in a heim joint vs a TRE.
post #15 of 24 Old 07-30-2013, 07:43 AM
rambo3489
I disagree. Maybe the joint itself. But there's a bolt through it to worry about. Which is grounds for play. Mines been fine no complaints. But to me a TRE would have less play. Until it's worn..
<a href="
THE YJ MY WAY</a>
