Heater won't blow unless driving - JeepForum.com
post #1 of 14 Old 11-07-2012, 11:03 AM Thread Starter
jhyj4life
My heater won't work unless I'm driving down the road, even with the switch turned on high, med or low. While I'm driving it will blow hot. I didn't know if I should jump right in and change the blower motor or if there would be something different that I should look into first?
jhyj4life is offline
post #2 of 14 Old 11-07-2012, 11:13 AM
Reddy89
Sounds like your getting outside air, hence you only get it to "blow" while moving... assuming the motor is always running.
Is your blend door moving when you switch between heat and vent?
Reddy89 is offline
post #3 of 14 Old 11-07-2012, 11:18 AM
turpehar
1977 CJ5
Is the blower motor actually coming on? If not, just under the glove box there is a plug that you can unplug and connect a ground and hot wire to and see if he motor will come on. If not the motor is dead. If it does come on, check the fuse for the heater. Could be in the heater control, which can also be relaced. You could put in a 12 volt power source with a switch to the fan for temporary purpoes until you figure this all out.
Swapping out the blower is about a 2 hour job.
Tools required
1/2" socket and ratchet with short extention
1/2" wrench
7/16" socket and ratchet with short extention
7/16" wrench
Phillips screw driver
1/4" nut driver or equivalent wrench
Razor scraper
black RTV silicone
I've been married so long I don't bother looking
both ways before crossing the road.
(Trial + error)*Upgrades) - $ = (mac-n-cheese/hot dogs)+experience
turpehar is offline
post #4 of 14 Old 11-07-2012, 11:23 AM
jokerchief462
Check the fuze, check the on/off sw on the control panel works (ohms) you actually have to pull the heater control panel out of the dash it is on the right hand side of the panel you will see how it is actuated by the levers. check the output from the 3 stage fan switch to the resistor (ohms) inall three positions, check continuity through the resistor and then on the firewall make sure the wire (single lead) is hooked up. Then check power to the blower motor. All before buying a new blower motor. Somehow mine was disconnected in the last year.
jokerchief462 is offline
post #5 of 14 Old 11-07-2012, 02:10 PM
YJ346
My 1995 YJ did the same thing. I changed the fuse located below the steering column and was as good as new.
YJ346 is offline
post #6 of 14 Old 11-08-2012, 09:50 AM Thread Starter
jhyj4life
Thanks for all the posts and help. I feel like an idiot. Ended up being the fuse under the dash. Thanks again for all the posts!
post #7 of 14 Old 11-08-2012, 09:59 AM
Rproject
1987 YJ Wrangler
Don't feel like an idiot. We all have DOH! moments here/there.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #8 of 14 Old 11-08-2012, 06:44 PM
phottomatt
2010 JK Wrangler
Sorry to hijack but sounds like your done with the thread. Mines doing it also, I've changed the controller the relay, checked the fuse and hot wired the motor so I know it works. At this point I'm just gonna hook up a switch directly to the motor but not sir the best way. Should I use a relay and fuse, maybe a switch with built in relay? Any ideas and instructions would be awesome. Thanks.
2010 Flame Red Sahara, Rough Country stubby bumper/winch, Body Armor rock sliders, stiff spring mod and RC 2.5" series II spacer lift (~3.5" total lift), 33X12.5 Duratracs on 15" MB72s.
2007 Grand Cherokee Limited, Red Rock, 5.7L HEMI
phottomatt is offline
post #9 of 14 Old 11-08-2012, 08:26 PM
ROTTEN
I'm going to just put this out there.
I ran into a problem where everything worked but I only got heat when I pressed the gas. So when the engine was off but power was on it would work great. I ended up shoving a bent up curtain rod under the flap to allow air movement. This year I discovered that one of the vacuum hoses going to the heater control was in the wrong spot.
Maybe that can be helpful to someone doing a search in the future after looking for fuses and relays and all that
I'm new
ROTTEN is offline
post #10 of 14 Old 11-08-2012, 11:37 PM
jokerchief462
My vacuum lines have been gone for awhile. I have the vacuum block but have no idea where the two output lines go. Replaced the heater control panel and the bad cables. All seems to work OK. What did the vacuum lines control???
post #11 of 14 Old 11-09-2012, 03:37 PM
ROTTEN
They control the flaps in the cowl to open and close
I'm new
ROTTEN is offline
post #12 of 14 Old 04-01-2013, 04:55 PM
phottomatt
2010 JK Wrangler
Well I'm back at it again, My blower worked for a while with my switch and direct hot from battery but now the blower stopped again. I fear I have killed the motor this time. I am not looking forward to or even sure I can get it apart enough to change it. From what I've read so far the defroster is required for PA state inspection.
post #13 of 14 Old 04-01-2013, 06:17 PM
ROTTEN
How is your blower wired to to the battery? Fuses ? Are you using the resistor?
I'm new
ROTTEN is offline
post #14 of 14 Old 04-01-2013, 06:29 PM
phottomatt
2010 JK Wrangler
Directly wired to bat with a 20amp fuse and switch (always hot) and grounded to body. I should add it blew 2 15amp fuses so I went to a 20, which is standard for this vehicle.
