Heater wiring trouble HEEELLLPPP!!!!!! - JeepForum.com
post #1 of 6 Old 09-08-2013, 02:00 AM Thread Starter
Martimus
Ok I am still working on this 92 yj I got and now found out why the heat dont work someone cut all the wires on the back of the switch and tossed the plug and then gave up PLEASE tell me witch wire goes to witch little plug on the low med high switch I already put terminals on the wires just dont know wher they go Thanks
Martimus
Martimus is offline
post #2 of 6 Old 09-08-2013, 08:08 AM
superj
Dang, that sucks. Hot morris 4x4 tech section for the 94 manual. That will have your wiring. I have no idea on which on or I would tell you. I have ac so I can't just run out and look without dropping the inside unit
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 6 Old 09-08-2013, 10:50 AM Thread Starter
Martimus
Thanks I will see abought that this is just one fo many wireing issues I have run into on this thing but I think its the last
Martimus
Martimus is offline
post #4 of 6 Old 09-08-2013, 12:27 PM
superj
That's good. You can usually find a factory service manual by googling or even doing a search on this forum.
superj is offline
post #5 of 6 Old 09-08-2013, 04:16 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Get a multi meter and find which wire at the switch has 12 volts when the ignition switch is in the ACC position. That is the fused feed for the switch which in turn feeds the three speed blower switch. Trace the wires back from the blower motor resistor pin A is low speed, pin B is med speed, pin C is the high speed setting.
This is for a '94 YJ so the wire colors may be different but the layout should be the same.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is online now
post #6 of 6 Old 09-08-2013, 07:04 PM Thread Starter
Martimus
Thanks its done and working great
Martimus
Martimus is offline
