Heater Upgrade Problems - JeepForum.com
post #1 of 3 Old 10-25-2005, 01:12 PM Thread Starter
wolf3902
I did the heater blower upgrade this past weekend. Everything went well and I put a new core in while I was in there.
The problem is that the next day I started it and the low speed was not blowing at all. turned it up to medium and high and back a few times and it finally started blowing on low. However, it is not blowing as strong on low as when I first installed it. Not even as good as the old motor. Med. an High are still good and more powerful than the old blower.
Any ideas of what to check or replace?
'93 YJ 2.5 Jasper; 5 speed
All stock, waiting to be reborn.
6/19/05 ...2" BDS suspension lift...the rebirth has begun!!!
ONE NATION, UNDER G O D
Support It, or Leave It!
wolf3902 is offline
post #2 of 3 Old 10-25-2005, 05:36 PM Thread Starter
wolf3902
I'm sure it is some sort of resistance pack of sorts, anyone know where to find this part on the Jeep? The motor only has one hot and one ground going to it, so it isn't in there.
wolf3902 is offline
post #3 of 3 Old 10-26-2005, 12:48 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
The resistors on mine are mounted in the air tube coming down from the cowl vent that connects to the top of the heater assembly, behind the right side of the dash.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
heater blower upgrade FITZER123 YJ Wrangler Technical Forum 3 09-29-2009 04:25 PM
YJ Heater Upgrade Question Snipeston YJ Wrangler Technical Forum 4 01-16-2009 01:38 PM
Heater upgrade? Millinski YJ Wrangler Technical Forum 3 11-26-2005 02:45 PM
Just completed heater upgrade on my YJ riverman YJ Wrangler Technical Forum 5 06-02-2005 11:04 AM
Heater Control Upgrade...is it possible? SgtSki TJ Wrangler Technical Forum 10 09-11-2002 11:29 PM
