heater troubles on my 95 yj - JeepForum.com
post #1 of 4 Old 12-30-2011, 08:59 PM Thread Starter
95yjdeathtrap
Hey im a nub. i need some advice on fixin my heater. im pretty sure its the vacume or blower motor but im not for sure. Any advice on anything to do with the heater would be helpful.
95yjdeathtrap is offline
post #2 of 4 Old 12-30-2011, 10:06 PM
FizzMaster15
What's the symptoms? More info needed
FizzMaster15 is offline
post #3 of 4 Old 12-31-2011, 09:25 AM
1SASjeepster
Fizzmaster15 is right. Without any description of your problems, how could we possibly help you?
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #4 of 4 Old 01-02-2012, 11:41 AM Thread Starter
95yjdeathtrap
I figured out wat the problem is. The entires witch is bad so I need a new switch.
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 05:20 PM
heater help: not the usual heater problem doug davis TJ Wrangler Technical Forum 2 12-06-2010 06:34 AM
Reverse heater lines at intake 4.2 (front to heater core/ rear to bypass port) Chris Aunchman YJ Wrangler Technical Forum 1 07-27-2010 02:16 PM
YJ Heater Core and Heater Motor Replacement?? Boston Mangler YJ Wrangler Technical Forum 11 11-29-2009 09:31 AM
Heater troubles nshaver2 YJ Wrangler Technical Forum 1 12-09-2007 03:47 PM
