Heater problems - JeepForum.com
post #1 of 2 Old 09-11-2011, 09:46 PM Thread Starter
jth0033
1987 YJ Wrangler
Heater problems
Well I come to JeepForum once again for help. The other day I went to clear the front window after a cool night and no top and I realize that my heater doesn't work. No sound, no air, no nothing. I'm sure this has been covered somewhere but I am kinda stumped. Can anyone help me out?
jth0033 is offline
post #2 of 2 Old 09-12-2011, 12:00 AM
89yjsahara258
Did you check the fuse? Do you have 12v at the blower motor (orange/black wire under the battery) when the climate control is in the defroster or heat position? Another place to check is how the resistors look. They are found by removing the red panel on the passenger side of the heater box. The plug going in to the resistors also should show 12v on one, then two, the three wires as your increase your fan speed on the climate control.
I just finished chasing this problem down on mine after installing a blazer blower motor in mine. Turned out that the switch plug was not completely connected to the fan speed switch. It had come loose driving.
Anyway I hope this gets you started... No pun intended..
Spencer
89yjsahara258 is offline
Heater problems Bedlam_YJ YJ Wrangler Technical Forum 6 10-15-2010 05:26 AM
Heater problems Renees05 TJ Wrangler Technical Forum 6 10-10-2010 01:41 PM
'98 Heater problems myriad360 TJ Wrangler Technical Forum 4 03-11-2009 08:31 PM
More Heater Problems JBWrangler2000 TJ Wrangler Technical Forum 6 01-06-2008 06:33 PM
Heater Problems chadc84 TJ Wrangler Technical Forum 10 11-06-2007 08:14 PM
