Heater not working - JeepForum.com
post #1 of 20 Old 10-26-2007, 08:49 PM Thread Starter
blue1989yj
blue1989yj's Avatar
Heater not working
I had my dash apart last year and the heater worked fine. Was laid up with back surgery for a while, went to use heater and got nothing. All vents open and close. I checked all plugs I could find and they seem OK. The fuse is good and I even put a new one in for good measure. The blower does not operate. I get no sounds at all from the system. Any thoughts or suggestions. Thanks for the help.
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline
post #2 of 20 Old 10-26-2007, 10:00 PM
timatoe
timatoe's Avatar
There's a little orange wire under the battery, it plugs into a terminal on the firewall that powers the blower. I'd start there and make sure it's connected. There's also a variable resistor on the heater box that can go bad, and then the motor.
timatoe is online now
post #3 of 20 Old 10-26-2007, 10:02 PM Thread Starter
blue1989yj
blue1989yj's Avatar
Thanks. Does this go into a terminal with other wires? If so it looks connected but the terminals are corroded. I will clean those off tomorrow and go from there.
post #4 of 20 Old 10-26-2007, 10:21 PM
timatoe
timatoe's Avatar
No, on mine it was just like a spade connector sticking out of the motor. (Just the one wire)
post #5 of 20 Old 10-30-2007, 03:16 PM Thread Starter
blue1989yj
blue1989yj's Avatar
All is good with the wire. What steps would you recommend taking from here? Thanks.
post #6 of 20 Old 10-30-2007, 03:28 PM
pushead
Run a wire from your batter straight to the terminal sticking out from the motor under your batter tray. If it kicks on you know its good and can eliminate that.
Its not a jeep if it dont have 4wd.
pushead is offline
post #7 of 20 Old 10-30-2007, 04:53 PM Thread Starter
blue1989yj
blue1989yj's Avatar
Thanks. I will try that as well.
post #8 of 20 Old 11-02-2007, 05:06 AM
stib4
You should have asked me. Run a wire from battery to blower that will tell you the most. Oh and where are pictures of the jeep painted all I see are the old blue pics
stib4 is offline
post #9 of 20 Old 11-02-2007, 05:55 AM
GreggieAtTheBat
Recheck the fuse
I had this issue a while back. The fuse was good (checked with ohm-meter), replaced it anyway, still no heater fan. Started going through the entire circuit with multimeter (looking for 12V at all points along the circuit path). When I touched to the contacts to the fuse contacts (the small exposed test points) the fan kicked on - the contacts in the fuse block were loose.
It took some time to figure out the right placement of the fuse, and from time to time it would stop, I just reached down and hit the fuse with my finger until the fan kicked on. This works for a little while but now (as of about 3 months ago, haven't fixed yet) the arcing as the fuse makes/breaks contacts eroded the fuse blades, and one of them has now broken off in the slot. SO I have to get in there with a needle-nose pliers to pull the broken blade and then figure out how to properly repair the fuse-block contacts. Maybe aluminum foil wrapped on the blade; just have to make sure I can do that without shorting across contacts.
GreggieAtTheBat is offline
post #10 of 20 Old 11-03-2007, 08:23 AM Thread Starter
blue1989yj
blue1989yj's Avatar
It is up and running now. There was corrosion on the terminal at the firewall and the wire was also frayed. I put in a new wire and spade connector and am good to go now. Thanks everyone for your help.
post #11 of 20 Old 11-03-2007, 08:53 AM
timatoe
timatoe's Avatar
Blue, good to hear you got it up and running.
Originally Posted by GreggieAtTheBat
.......the contacts in the fuse block were loose....
...SO I have to get in there with a needle-nose pliers to pull the broken blade and then figure out how to properly repair the fuse-block contacts....
Mine did the same thing, with the same fuse. I pulled the entire block out...the only way I could figure to fix it was to replace the fuse block. I couldn't find anywhere that had just the little connectors that fit in the block. Anyhow, I got one of THESE from the parts store, and bypassed the block.
post #12 of 20 Old 11-03-2007, 12:53 PM
Jeep25
Heat is good.
Jeep25 is offline
post #13 of 20 Old 01-12-2011, 08:04 PM
Stryker777
Stryker777's Avatar
Does anyone have a picture of this orange wire location? I have been looking and I don't see it anywhere on mine. Mine is a 95. The blower rarely turns on but does sometimes if I turn off the Jeep and back on a few times. Seems like a bad connection but can't find it.
92 XJ, 4.0 NP231 - Stock to rebuild for my daughter, 235x75R15s
95 YJ, 2.5 NP231- 1" shackle, 4.0 tb, 19lbs injectors, e-fan, 31x10.5R15 Treadwright tires.
93 ZJ, 4.0 w/AW4 NP231 - 2" BB, 1 inch spring lift, 31x10.5R15 Cooper AT3 tires.
In GOD we trust. It's a Jesus thing.
Stryker777 is offline
post #14 of 20 Old 01-13-2011, 04:27 AM
Mark05059
the connector is on the firewall just under the battery tray. If the orange wire isnt connected to it then its dangling somewhere near it. Sorry I dont have any pictures but you should be able to find it.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #15 of 20 Old 01-13-2011, 04:35 AM
Stryker777
Stryker777's Avatar
Thanks Mark. I am guessing it plugs in on the bottom side of the blower housing under the battery tray? I have not seen it yet but think I found a picture of it. Maybe I can find it and get it hooked up before I leave this morning. It is 3 degrees today and I have a long drive.
AC/Heater Not working lvjeeps TJ Wrangler Technical Forum 2 06-05-2009 03:20 PM
Heater Not Working on '05 TJ cmorra68 TJ Wrangler Technical Forum 2 11-12-2008 10:04 AM
Heater not working... gearheadjlm TJ Wrangler Technical Forum 18 12-07-2007 09:06 PM
Heater/Fan not working Kahu TJ Wrangler Technical Forum 1 11-03-2005 10:15 AM
Heater not working todnshay YJ Wrangler Technical Forum 6 07-19-2003 01:53 PM
