Heater not working - JeepForum.com
post #1 of 12 Old 03-15-2013, 11:08 AM Thread Starter
wrestler22115
Heater not working
My heater worked perfectly fine untill i replaced my dash lights. I put all the screws back in and the next morning there was no heat. I figured it was the switch. So i took everything apart again and wiggled the wires that go to the switch. With the heater control assembly pulled out it worked. Then when i pushed it back into place the heat cut off. I tried fooling around more with it now there is no heat no matter what. It wont turn on. Do you have any clue what it could be?
wrestler22115 is offline
post #2 of 12 Old 03-15-2013, 10:14 PM
Reno72
I assume you're talking about the fan. The first thing to check is the fuse, since it came on and went back off it sounds like a wire or connection at the control panel, check all those. I tester is cheap and really helps in finding where the power is not reaching the switch.
Reno72 is offline
post #3 of 12 Old 03-16-2013, 06:45 AM
jsawduste
2006 YJ Wrangler
Sell it or scrap it. It`s done for.
jsawduste is offline
post #4 of 12 Old 03-16-2013, 07:10 AM
RockWoRM
RockWoRM's Avatar
Of move to Ca. Don't need a heater here.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #5 of 12 Old 03-16-2013, 09:09 AM
jsawduste
2006 YJ Wrangler
Darn you Worm. Looking outside at another snowstorm and the long range is still 20`s and 30`s.
Nick is *****ing it`s to hot. I need to move to someplace warm.
To the OP, your 19 years old. You figured out how to take the dash apart. Found what bulbs you needed. Either you did it by trying on your own or you looked/found a how to thread/article.
Ever consider typing in "YJ heater wiring" or "YJ heater blower" in the search function ? Not trying to be a dick but I bet you could program the latest electronic gizmo with your eyes closed.
For the more tolerant of us. At least explain your problem better. As Reno said "I assume your talking about the blower".
post #6 of 12 Old 03-16-2013, 09:30 AM
salsomano1a
does the blower blow at least cold air or its not working?
salsomano1a is offline
post #7 of 12 Old 03-17-2013, 08:52 AM Thread Starter
wrestler22115
Its not the mower. I know that 100% sure. I did research on other threads and the closest thing i came to was the vaccum on the back possibly came off.
post #8 of 12 Old 03-17-2013, 09:56 AM
jsawduste
2006 YJ Wrangler
Your YJ has a "mower" ? Is that factory or did you install it yourself ?
The vacuum line(s) are easy enough to reinstall.
post #9 of 12 Old 03-17-2013, 10:07 AM
Que89YJ
So the blower is working and it is blowing air it is just cold?
Que89YJ is online now
post #10 of 12 Old 03-17-2013, 10:13 AM
zweasel
If when you check the vacuum lines and find that, that is not the problem, take a look at the blower motor resistor. You have the old coil style in that year, you my have broken one of the coils that may have been just holding on. That could be you problem. just something else to look at.
zweasel is offline
post #11 of 12 Old 03-17-2013, 10:17 AM
Que89YJ
That is what I was thinking Z. That is why I asked to see if the blower was actually working.
post #12 of 12 Old 03-17-2013, 10:56 AM
Reno72
If the blower is workng but only cool air is coming out, you may have unhooked the cables that open and close your heat/cool air flaps, You should hear the flaps open and close when you pull the levers, you can see under the dash the cables moving the levers, one in the center of the jeep, one on the passenger side firewall.
Reno72 is offline
heater control , YJ
